Question about Hitachi CP-S210W Multimedia Projector
External speakers I have a DVD player hooked up to the Hitachi CP-S210, and external speakers hooked up to the projector. Sound is still coming out very muted on full volume, and the speakers hardly have anything coming out. What can I do to make all the sound come out of the speakers, in otherwords, bypass the speaker on the projector?
  • 2,336 Answers
I would bypass the speakers from the projector and connect the audio output from the DVD to a sorround sound system or to computer speakers.
Posted on Jan 17, 2008
Speakers blown hitachi cp-x2511n
Besides replacing the speaker, you can connect the unit to an external set of speakers such as surround sound, or desktop speakers, depending on what your setup allows.
Nov 12, 2013 | Hitachi Gst "hitachi cp-x2511n xga, 2700...
How do I change a bulb in a Hitachi CP-S210 Multimedia LCD projector?
There will be a panel that holds the lamp module in, usually on the base of the unit. Once removed the lamp is usually held in with two screws mounted on the body of the lam. Once replaced, ensure the lamp is correctly fitted and the panel then switch on and reset the lamp life in the settings menu.
Good luck, hope I was of help to you
Aug 04, 2011 | Hitachi CP-S210 Multimedia Projector
How do you set the closed captioning on the projector?
Its not usually the projector, but the video source (computer, DVD player, VCR etc...) that sets the closed captioning options - "the projector just projects what its given".
Here's the user manual - no mention of closed captioning
http://safemanuals.com/user-guide-instructions-owner-manual/HITACHI/CP-S210W-_E
Hope this helps
Mar 01, 2010 | Hitachi CP-S210W Multimedia Projector
Projector works fine, but does not show video
Hey. Sounds like you are using some kind of dual-view or extended desktop via the computer for video. This may sometimes be a problem. If you can see the desktop but no video using the projector it is not a projector problem. It is probably your grapic card och software problem.
Try different setups in the graphic cards settings, like the projector as primary monitor etc. That usually solves the problem.
/Patrik
Jun 05, 2009 | Hitachi CP-S210 Multimedia Projector
How do I reset the filter timer on the hitachi cp s210?
The reset function is in the options menu. Once you scroll through the menu locate the filter timer, forward to the timer locate reset, you then need to hold down the reset button on the bottom RH of the remote control.
May 07, 2009 | Hitachi CP-S210 Multimedia Projector
Red screen
I had a similar problem with the same projector. Replacing the computer to projector solved it.
Oct 25, 2008 | Hitachi CP-S210 Multimedia Projector
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
Hitachi cp-x430?
My projector is not Hitachi but I had a similar problem. My manual suggested checking under "signal" to make sure that "auto" was "on". The thing is, there were two places where "signal" came up on the menu. I had to go under "set-up" to "signal" and then I was able to correct it by setting "auto" to "on". I hope this helps.
Nov 01, 2007 | Hitachi CP-S210 Multimedia Projector
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
See all Hitachi CP-S210W Multimedia Projector Questions
Hitachi CP-S210W Multimedia Projector Logo
295 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
