Question about Zanussi WJS1265W Front Load Washer/Dryer
Washer stopped working
Only lights on are power and door lock all functions not working no other lights on
  • 4 Answers
I think your mother board has gone hence none of the other lights are coming on.
If you get the help of a competent Washing Machine engineer they will solve your problem, without having to replace the whole machine.
Regards,
David
Posted on Mar 08, 2008
I had my passenger headlight bulb replaced. Now when I go to start my 2009 buick lacrosse, my horn honks, wipers come on, trunk pops open and loud bass static on my radio.
Who replaced the headlamp bulb ? Take it back . Everything your having problems with are all controlled by the BCM - body control module . May have crossed wire's ,shorted etc....
This vehicles BCM functions as the Power Mode Master (PMM). Refer to Power Mode Description and Operation for a complete description of the power mode functions.
Body Control Module
The various body control module (BCM) input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The BCM functions include the following:
• Battery rundown protection--Inadvertent power--Refer to Interior Lighting Systems Description and Operation .
• BTSI/automatic transmission shift lock control--Refer to Automatic Transmission Shift Lock Control Description and Operation .
• Bulb check--Refer to Instrument Cluster Description and Operation .
• Chimes--Refer to Audible Warnings Description and Operation .
- Check gages
- Content theft deterrent
- Door ajar warning
- Headlamps ON
- Key-in-ignition
- Oil reset
- Park brake warning
- Seat belt not fastened
- Turn signal ON
- Vehicle theft deterrent
• Door lock interface--Refer to Power Door Locks Description and Operation .
• Exterior and interior lighting control--Refer to Exterior Lighting Systems Description and Operation .
- Automatic lighting control
- Backup lamps
- Daytime running lights (DRL)
- Fog lamps
- High/low beam head lamps
- Park brake lights
- Turn hazard lamps
• Gage control--Refer to Instrument Cluster Description and Operation .
• Heated seats--Refer to Heated Seats Description and Operation .
• Horn interface--Refer to Horns System Description and Operation .
• Instrument cluster indicator control--Refer to Instrument Cluster Description and Operation .
• Interior lighting--Refer to Interior Lighting Systems Description and Operation .
• Key-in-ignition sensing--Refer to Audible Warnings Description and Operation .
• Parking brake state sensing--Refer to Brake Warning System Description and Operation .
• Retained accessory power (RAP)--Refer to Retained Accessory Power (RAP) Description and Operation .
• Rear compartment interface--Refer to Power Door Locks Description and Operation .
• Rear defogger--Refer to Rear Window Defogger Description and Operation .
• Remote function control--Refer to Keyless Entry System Description and Operation .
• RFA communication link--Refer to Keyless Entry System Description and Operation .
• Seat belt use sensing--Refer to Seat Belt System Description and Operation .
• Theft deterrent vehicle/content--Refer to Content Theft Deterrent (CTD) Description and Operation or Immobilizer Description and Operation .
• Washer solvent level sensing--Refer to Wiper/Washer System Description and Operation .
• Wiper/washer--Refer to Wiper/Washer System Description and Operation .
May 07, 2018 | Buick Cars & Trucks
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
I have a 2005 Buick Terraza. When I put in gear and drive it starts dinging and indicates that a side door is not closed. They are and I have cleaned the contact plate.
This warning indicator is controlled by the BCM - body control module . You cant turn it off , you need to fix the faulty input switch that signals the BCM that the door is open .
Body Control Module
• Battery rundown protection--Inadvertent power--Refer to Interior Lighting Systems Description and Operation in Lighting Systems.
• BTSI/automatic transmission shift lock control--Refer to Automatic Transmission Shift Lock Control Description and Operation in Automatic Transaxle - 4T65-E.
• Bulb check--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Chimes--Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
- Check gages
- Door ajar warning
- Headlamps ON
- Key-in-ignition
- Oil reset
- Turn signal ON
• Door lock interface--Refer to Power Door Locks Description and Operation in Doors.
• Exterior and interior lighting control--Refer to Exterior Lighting Systems Description and Operation in Lighting Systems.
- Backup lamps
- Fog lamps
- Park brake lights
- Turn hazard lamps
• Gage control--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Heated seats--Refer to Heated Seats Description and Operation in Seats.
• Horn interface--Refer to Horns System Description and Operation in Horns.
• Instrument cluster indicator control--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Interior lighting--Refer to Interior Lighting Systems Description and Operation in Lighting Systems.
• Key-in-ignition sensing--Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
• Parking brake state sensing--Refer to Brake Warning System Description and Operation in Hydraulic Brakes.
• Retained accessory power (RAP)--Refer to Retained Accessory Power (RAP) Description and Operation in Retained Accessory Power.
• Rear compartment interface--Refer to Power Door Locks Description and Operation in Doors.
• Rear defogger--Refer to Rear Window Defogger Description and Operation in Stationary Windows.
• Remote function control--Refer to Keyless Entry System Description and Operation in Keyless Entry.
• RFA communication link--Refer to Keyless Entry System Description and Operation in Keyless Entry.
• Seat belt use sensing--Refer to Seat Belt System Description and Operation in Seat Belts.
• Theft deterrent vehicle/content--Refer to Theft Systems Description and Operation in Theft Deterrent.
• Washer solvent level sensing--Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
• Wiper/washer--Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
As far as the sliding doors , pull the fuse's
Jan 12, 2018 | Buick Cars & Trucks
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
I need help with my Duet washer
it sounds like an electronic problem with the board.
Nov 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Machine partially fills and then stops working.
THE RCD SWITCH is concealed on the inner side of the hindges of the door or on the top innerside of the door. it is a simple push switch which has a mechanism of push to on/off
this switch has got stuck in off position.
change this switch or spray a drop of rust removal oil. it will start functioning
Aug 27, 2009 | Whirlpool AWM8123 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
73 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
