Bosch Maxx WFL 2260
Washing machine will not turn, fills and drains okay, drive belt intact, light grey deposit all over inside of machine clicking can be heard from control panel
  • 2 more comments
  • bugsy416 Jan 17, 2008
    BOSCH MAXX WFL 2260
  • nogenius May 22, 2008
    I have the same problem, I have tipped it over and removed and replaced all the wiring after which it works a couple of times then stops. Whats wrong and how do i fix it?
  • frsw05883 Oct 31, 2008
    same problem anyone have ananswer
  • robert samples May 11, 2010
    i need your brand and model number
    President:
  • 1,314 Answers
Thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
Posted on Jan 17, 2008
  • robert samples Jan 17, 2008
    repost your promblem under bosch and put your model number you will get a better response that way
Maxx WFL 2260 wash. machine will not fill/spin
Could be the intake valve solenoid, or control panel fault
Mar 26, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wfl 2260 5 years old The drum does not turn the
if you can here the motor running have you checked the drive belt is still fitted to the drum,,,they fall off at times or wors still they brake,,,
Jul 04, 2010 | Bosch WFL 2063 Front Load Washer
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Mar 28, 2010 | Bosch Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Maxx 2260 washer won't drain or spin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Feb 24, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Oct 21, 2007 | Bosch WFL 2063 Front Load Washer
Washing Machines Logo
738 people viewed this question
Top Washing Machines Experts
