Question about Samsung SyncMaster 710N 17" LCD Monitor
Flickeing like a dying fluorescent light bulb
I have a SyncMaster 710N from 2005, and late last year it began to flicker like a dying fluorescent light bulb. I've tried changeing the refresh rate, unplugging it and repluggin it, nothing i do seems to help... exept when I hit the auto adjustment button on hte monitor, which seem to fix the problem for the duration of the auto-adjusting cycle.
If it helps to know this, my monitor is being used with a PowerPC mac mini of the same vintage, that is running OS 10.4.11
  • 30 Answers
Actually this is a 'warning' signal from your lcd monitor. The problem is your lcd ccfl lamp are near to their life, need to change. The ccfl lamp like our home fluorescent lamp, when the lamp need to dead, the lamp will flickering first, after some time, will totally off(dead). So, this is a signal for you. Some lcd monitor, when their inverter board are using fairchild inverter ic(oz series), will easily shutdown your monitor when they detected some flickering on your screen (ccfl lamp). If you need more information on repair your lcd monitor please visit http://www.fastrepairguide.com . Thanks.
Posted on Jan 18, 2008
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
No backlight on Samsung 710N LCD Monitor
No, it is not easy to change the backlight on an LCD panel. The backlight is an integrated part of the LCD panel itself. The backlight for LCD monitors is also model and manufacturer specific, so there's no easy place to order a backlight to do it yourself. The good news is that your Samsung monitor should come standard with a 3 year warranty, so if it's less than 3 years old, you can call Samsung and they'll repair/replace it for free. If it's over 3 years old, then you may need to repalce the monitor... or pay to have it repaired.
Mar 07, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Oct 26, 2007 | Sea Gull Lighting Sea Gull Energy Saving...
Monitor works for about 30 mins then goes blank with a messahe reading 'Not Optimum'
Hi Rick I have the same problem. Have you found a solution yet? I had the power supply tested, that is not the problem. It seems to go off when it gets hot. If I point a fan at it, it seems to last longer before blacking out. Pete
Feb 23, 2007 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung SyncMaster 710N 17" LCD Monitor Logo
706 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
