Question about Rinnai EnergySaver 556 Air Conditioner
Ductless heater shutting down
My Rinnai heater shuts off every once and a while (between 1 - 4 days) and the Lo 60 64 lights blink. If I push the on/off button to turn it off and then on again the heater fires up and works again until it shuts down again day(s) later. I was told by Rinnai that the spark ignition system (gap) may need to be reset. I would like to do this myself and save the expensive service call for what seems like a simple fix. Any suggestions?
  • rtobsession Feb 27, 2008
    I am having the same problem with shutting down. Except, it is within every 1-2 hrs. gets real cold in my apt at night because I am asleep and can't keep turning it back on. I'm not to technical though, so not sure what it can be or if i can fix it myself.
  • 1,420 Answers
There is a small wiring harness that goes from the main board down to the sparker board at the very bottom of the heater. Disconnect this harness and reconnect making sure all pins and contacts make good connection. If it continues, replace the wire harness. Also make sure the outlet that the heater is plugged into is a grounded outlet. Stray voltage can interrupt the thinking of this unit.
If all connections are good and the unit is grounded, you are probably looking at replacing the sparker board. I do have these parts and would be more than happy to send them to you for a donation.
Posted on Jan 18, 2008
    Problem Solver:
  • 12 Answers
A gas appliance should be maintained by a expert for safety issues
My heater keeps blinking and a code on the top says 11...also ..if i unplug the unit while i wait for it to get fixed does the pilot light go out?
There is no pilot light on this model. An 11 error code tells us that there is no gas supply to the heater. Could be a bad gas valve, dirty igniter, gas got shut off somehow, dirty burner, etc... All you can do is make sure the filter is clean, a technician will need to open it up. Sorry.
Apr 09, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heat shuts off, red power light blinking and number 12 blinking on the display screen.
You may have had a power failure. The situation could be as simple as turning the stove off and on again. The 12 code means flame failure. Gas heater are nothing to mess around with if you don't understand them completely. Don't remove anything from the unit unless you are very sure what you're doing. A call to Rinnai is in order if the code keeps coming on. Good luck,
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a rinnai energy saver 1004f heater and as soon as I turn it on, it starts blinking either the number 11 or 12 and the heat shuts off. Help!
Ignition failure caused by either lack of gas, the electrodes are not the correct gap, restriction in the venting system or the spark is grounding prior to the electrodes. Check spark by holding spark wire close to cabinet (1/4"). Check gap across bull horns (electrodes) they should be no more than 3/16. Make sure all gas valves are on and all wires to gas valve are tight. After these checks, you will need a qualified technician to perform some tests on components.
Mar 07, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes., look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 1001FA Energy Saver - Green Light Goes Out!
It is time to replace it. You cannot get some components like the main board.
Dec 15, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Filter blinking light
Vacuum the back of the heater near the vent pipe and the sides near the floor.
Nov 20, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE 1001FA
i have a rinnai rhfe 1001fa heater and when its real cold sometimes it will shut down all the lights go out and i have to shut it off then turn it back on and sometimes it still wont start and i will leave it of for a day or two then try it and it will work it seems to act up more when its colder i am running it this fall so far no problems this unit is around a 1994 or so and has not given any trouble till this started last winter
Mar 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai EnergySaver 556 Air Conditioner Logo
258 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
