1998 Mercedes-Benz C-Class Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Garage code How do you program your garage code in a 1998 mercedes c230
Anonymous
Level 3:
  • Master 1,586 Answers
  • Posted on Dec 05, 2009
Anonymous
Master
Level 3:
Answers
1586
Questions
0
Helped
820782
Points
5018
In my Audi, and in my mother's Avalon, you choose which of the buttons on the visor you want to use, hold it down, and while holding it, you aim your garage door opener at the visor and press the button. This allows the car's memory to scan the code that the opener sends, and programs it into the car's opener for the selected button.
Driving along, and my 1998 c230 Mercedes cuts off on me. When trying to restart, it won't make a sound. After about 45min to 2hrs it starts. why is this?
Replace cam positioner sensor and crank positioner sensor one is failing hard to tell which on the c230 just do both fast and easy
My 1998 c230 mercedes evaporated
What evaporated? Cant help you with your problem description. Too much information is never enough when diagnosing problems from a remote location.
1998 C230 Mercedes factory stereo reset instruction
you can try removing the negative cable from the terminal on the cars battery for a few seconds (but it will reset time clock as well)
2helpful
Reset radio code mercedes c230 how to
i want tape code ?benz c230 tape model cm2299 srial no.2299w0926802b
Radio code fro 1998 mercedes c230
my 1998 Mercedes remote, stop working. I've changed the batteries in the remote and changed the car battery.. but my car still will not engage the key to start.. what do i do??
2answers
I just replaced the battery in my 2000 mercedes c230 kompressor. does anyone have the radio code for it?
Check the inside of the owners manueall. If that dosent work Mercedes shold give you the code or reset it for free. Dont try to put randum codes it will lock the raidow up.
Good luck
1helpful
2answers
Engine light on a 2005 Mercedes C230
the engine light on some mercedes come on quite often due to a faulty ground issue either the ECM ground wires and there is about 17 of them going to the ECM itself also can be the engine sensors ground
1helpful
The display on the radio and the radio wont come on its mercedes benz C230-1998. had to charge the battery
you will probably have to enter a code for your radio to work again, look in your owner's manual and if you do not have one then you will have to call a dealer and get the code or try searching online, sometimes you can get help there
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
