Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp light Does anyone know the code (have service remote) to get the light to go out on front of the TV after replaceing the old lamp with a new one..Thanks SnuggleTime
I have a similar problem. i just replaced the lamp and i get a picture and sound, but the lamp indicator stays a solid orange, which the manual says that the lamp is about to expire. anyone have a solution, i would really appreciate it!
Posted on Nov 22, 2008
  • rayo138 Nov 22, 2008
    i also forgot to mention that i did unplug it overnight and i still have the same problem.
  • Zenith Master
  • 5,138 Answers
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Posted on Apr 20, 2008
    Problem Solver:
  • 17 Answers
To reset lamp timer, I've used an LG service remote# 105-201M. Not sure what the proceedure was in getting the lamp timer reset, but was able to do it with this remote.
Posted on Jan 22, 2009
Need service remote to do that
Posted on Jan 23, 2008
  • Zenith Master
  • 8,617 Answers
The light should go out automatically after replacing the lamp. try unplugging the set for 5 minutes then plugging it back in. that should reset it. Let me know if this helps.
Posted on Jan 20, 2008
I have a Sony model KDF-e55a20. I just changed the buld but I still don't get any picture all I get is the power on light blinks 3 times. Does anyone know what the problem is?
Sir reset the lamp timer of your unit.
1 Press "Display" on the remote, followed by the 5 button, then the sound up key, and "power on". Do this while the tv is in stand by mode.
2 Then press "jump" 3 times to enter DE service menu.The tv screen will display the total lamp time hours.
3 Reset the the lamp time by pressing channel 3, then mute, then enter.This will return lamp timer back to 0. Hope this may help good day and best regards.
Aug 18, 2011 | Sony KV-36FV26 TV
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is...
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
My tv turns on, but there is no picture. The two green lights and one red light are flashing on the button in front. What do I do?
That means that the lamp may be defective and the TV needs service. You can replace the lamp yourself. The code is on the right side of the TV and on the lamp case. Get a replacement using this code from the store where you bought the TV or a Samsung Service Center.
Once you have the correct lamp (the wrong one may damage your TV), make sure your TV has been off for at least 30 minutes (cool down). The cool down will not happen properly if the TV is plugged into anything other than a wall outlet.
Open the lamp case and take out the old lamp and replace with the new one. Do not touch the glass with your hands and do not insert any objects into the case. Do not leave the old lamp near flammable objects or where children can access it.
I hope this helps.
Apr 13, 2010 | Samsung HLS4266 TV
5 yrs old, blinking green then red, replaced lamp 4 months ago
You very well could have problem with the Ballast board that powers Lamp or your Lamp Fan maybe defective and if you need orinagnal hand unit for set Call Encompass Parts Distrubtion or Go to their website type in Model number they will list Parts /Prices for your model.
1-800-638-3328 Mats Electronics also sells handunits .To reset timer
Hold VOL- on front of TV and Menu on hand unit at same time for 5secs
if this does not work try it in reverse Hold Menu down on TV and Vol- on hand unit. Check your Lamp Fan see if it quits running while turning set on,if it starts and stops it is defective, other wise Follow wires that Lamp plugs into it will connect to Ballast board that powers Lamp CK it Problem M/B Ballast Board.
Feb 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Hello. I have have an HLS5087W DLP tv and I have no sound or video. I just replaced the lamp and the color wheel so they are brand new. Any ideas what could cause the problem? I don't get any video - even...
Do you see any light blinking at TV front?
What was previous symptoms that you decided to replace lamp and color wheel?
Do you have service manual/ schematics in hand?
Let me know above to diagnose problem.
Thanks.
Nov 13, 2009 | Samsung HL-S5087W DLP TV
SONY KDF70XBR950 TV. NO PICTURE OR SOUND. FIVE FLASHING RED LIGHT
5 times blink code means Lamp Driver error that can be problem of ballast supply or Lamp.
How old is this TV? Have you replaced Lamp recently?
Service manual of TV can be downloaded from HERE for small fee.
Let me know your finding to provide you more info.
Thanks.
Sep 11, 2009 | Sony Televison & Video
I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Trouble Codes - Flashing lights.
Looking at the lamp itself can give a very good idea of its condition,You should be able to remove the lamp safely from its compartment because you will not be close to the high voltage but make sure the set is totally unplug from the wall.There might other reason but the lamp is a good place to start.
Sep 21, 2006 | Samsung PLK405 40 in. Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
335 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
