Akai PT4298HD Rear Projection Television Logo
Posted on Jan 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My big screen tv show snow on all channels.
The strangest thing. Yesterday i went to look at TV and nothing...just snow on all channels. I can use the control to do the setting but nothing happens. I can do PIP and get the VCR to play the PIP but not on the regular screen. It will not let me swap PIP to large screen.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
264
Points
I have a 2005 color tv and i can not find my manual to correct the color on my set.can you help?
Anonymous
Level 3:
  • Master 871 Answers
  • Posted on Jan 17, 2008
Anonymous
Master
Level 3:
Answers
871
Questions
5
Helped
364060
Points
2104
Ok.
if you see only snow on the regular screen, might as well check the connecting antenna at the back since you mean all snow on all channels.
hope this helps.
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Advent Tv on direct tv with snow showing on screen
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Blank Blue Screen
If you go to menu do you get that on the screen?
I can only get snow on my tv screen
Does your controller turn the tv on and off?
2answers
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
No channels showing
If you are using Direct TV or Dish Network call their tech support.
If you are on cable TV, call for a service man.
I would say that your TV has lost its sync separater chip and it shouldn't cost more than $60 dollars to fix, if the repair guy is honest. It's a 30 minute job.
This message is from an electronics engineer, retired.
Pioneer sdp4682k
try the RGB or the S-video out of the Direct TV receiver.
Tv only has select channels
If you have a good cable signal connected to the TV and it receives channel 50 nice and clear but all lower channels have nothing but snow, then the tuner is defective and needs to be replaced. This is quite an easy thing to correct. Sometimes resoldering all connections inside the tuner will bring it back to life, but in either case the set should be serviced by a qualified tech.
3answers
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
