Question about Honeywell Surround HZ2200 / HZ2204 / HZ2205 Compact Heater
Honeywell surround heater shuts off
My heater turns on but after a few minutes it shuts off. It then sounds like it's trying to turn on. It does this for a while untill it finally turns back on. After which the process repeats itself.
  • 9 more comments
  • klj45 Mar 29, 2008
    my heater does the same thing
  • NeonCities Oct 23, 2008
    The problem seems to be a bad thermostat inside the heater, possibly overheating because of the way it is housed. It overheats, and shuts the heater off even though you've not reached desired temperature. Has Honeywell done a recall?
  • msilver1 Oct 30, 2008
    Heater shuts off before room get even slightly warm
  • Anonymous Oct 30, 2008
    my heater cuts off but when i move it arround it cuts back on like its not level
  • Anonymous Dec 02, 2008
    Mine does the same thing
  • Anonymous Dec 16, 2008
    My heater turns on for about a minute maybe two minutes and then shuts off and then about 5 minutes later it will turn on again for 30 seconds to a min. I can't heat the room if its not staying on.
  • nrebollido Dec 31, 2008
    my heater turns on and after 2 minutes it turns off with a click sound. i unplug it until i hear another click, plug it back on and it works again.. but the whole thing starts all over again.. LoL.. then one day it actually went on for more than 2 minutes.. so i left it on for hours. After that, i turned it off and unpluged it.. heard a click but ignored it. After a few hours i turned it on and it didn't work.. i shook it.. swore a few times but nothing worked. Now for some odd reason it's working again.. aaarrrrggghhh.. This heater sucks!
  • lbel2000 Feb 06, 2009
    heater turns off for no reason and seems to reactivate when it pleases
  • noheat2009 Feb 17, 2009
    I am having the same problem. Does anyone have the phone number from the manual?
  • Anonymous Feb 20, 2009
    Mine is on the floor next to my cat, and I know some cat hair got in there, so I'm wondering if it's shutting off so it doesn't overheat and catch on fire. I don't know, but it worked great until yesterday!!! Now my room is freezing!
  • Anonymous Apr 24, 2009
    same
Had the same problem. The cause: The coils have too much dust on them.
Soultion: Take the bottom of the base off and clean/vacuum. While the base is off, you also have access to the interior of the heater. Remove the 2 screws on the bottom front, then the 2 on the bottom back. The plastic panels will come off and you'll have access to all internal areas. Just clean thoroughly and you should be good to go. You wouldn't realize it, but even with a spotless house, the heater will **** any small particle of dust.
Posted on Dec 23, 2009
  • Danielle
    Danielle Oct 31, 2015
    How do you get the bottom off? Specifically those black screws?
They will replace it if you call the number in the manual
Posted on Oct 30, 2008
The heater comes on for a few seconds then shuts off but once or twice a week it comes on and operates like a normal heater
Mine does the same thing. I have a gas heater. It will fire up- run for less then a minute then shut off. then 2 minutes later does the same thing. I'm thinking of going with a differeny brand because this is using a lot of gas evertime it fires up just for a minute. if I turn it up it stays on till it reaches the temp then does that on off thing again. i think it is just the so called "feature" Honeywell is claiming to maintain the temp in our home, not realizing it is wasting your gas or electricity.
Feb 23, 2010 | Honeywell Programmable Thermostat Heater
Problem with used honeywell surround HZZ 2200. run for a minute then shut off.
the way i got mine to run is by pulling off the thermostat knob and then grab the pin and turn it the same way as to turn it up it will loosen it seems it has a mechanical thermostat and its pressure based so adjust it as needed and you can even put the knob back on ... gl
personally i just removed the pin entirely so it runs non stop dunno if that disables any safety features .....
Feb 19, 2010 | Honeywell Surround HZ2200 / HZ2204 /...
Oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Mar 17, 2008 | Honeywell HZ-710 Oil Filled Radiator...
My honeywell heater was working one minute and not working the next.
HI I have this heater and no manual , and I was doing research on the internet and found that these haeters have an automatic shut off if it gets too hot and it wont come back on for a while until it is cooled down. I just unplug mine awhile or turn it off and then it comes back on when it cools down.
Jan 02, 2008 | Honeywell HZ335 Ceramic Compact Heater
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
SET UP
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Heating)
OPERATING INSTRUCTIONS
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Nov 04, 2007 | Honeywell Surround HZ2200 / HZ2204 /...
Honeywell HZ7040 shuts off after few minutes
This sounds like a theromostat problem. If you're NOT still under warranty you should at least open the heater and look for the theromostat. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace. Good luck!
Dec 02, 2005 | Honeywell HZ7040 Compact Heater
Honeywell Surround HZ2200 / HZ2204 / HZ2205 Compact Heater Logo
8,749 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
