Question about Refrigerators
Whirlpool semi defrost refrigerator
I am getting power to frig but it wont get cold while cleaning it noticed a small piece of metal fell from behind freezer, unscrewed freezer top and the I guess you would call it part of thermostat wiring was broken, it is a u shaped wire with a plastic hose surrounding it, it is connected to outside temp control that has a push button to turn on defroster. Does anyone sell this type of wiring so that I can try to fix it myself? Thanks
  • 90 Answers
Best to call for help.
Posted on Jan 17, 2008
Refrigerator and freezer not coming up to temperature. replaced start device on compressor what else could be the issue
Some of these brand friges have a tendency to not defrost the freezer side properly. Ice builds up behind the freezer panel thus reducing air flow to the frig side. Having replaced all parts repeatedly on my WP frig, actually two of them, and losing food repeatedly, a WP repair guy said it was unrepairable. WP is crap. Their design is crap. Many side by sides are littered with cooling problems. The defroster coil, defrost sensor, and thermostat just dont work properly. In the end, I bought a diff. brand and will never buy wp again. Keep in mind how many brands are sister brands to wp and avoid them too.
Oct 12, 2014 | Whirlpool Refrigerators
Whilpool questions
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Whirlpool Refrigerators
Should I just junk this frig? We turned frig off manual defrosted and cleaned out plugged up line from freezer to frig. Frig and freezer worked fine for one month and then the same problem has happened...
Hi this probably has a bad defrost thermostat, its only a $10-15 part its located in the freezer behind the rear panel. Would need to be totally defrosted beore you changed it and usually requires a bit of wiring but nothing complicated just need to be handy with wire strippers.
Sean
Mar 27, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is very cold but main frig is not cold at all, we defrosted cleaned all ice built up under plate in freezer and still warm
did you check freezer fan behind the freezer? If not working check the wiring for it. If broken fan replace it. Find no leak in door gasket. Temp setting must be at least 5 degree.Thanks.
Jan 30, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
I have a whirlpool frig for about 5 years now and as of the last week the freezer is icing up on the left side where the door opens and the refrigerator part doesn't get that cold even with the controls...
Check the following: is the defrost timer cycling. If it is is the heater working, located behind the freezer back panel, defrosts the Evaporator coil that makes cold.
Sep 19, 2009 | Whirlpool Refrigerators
Have a Whirlpool frig. gets very hot around the door????
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
