Back to:
Tags:
Compaq D310  PC Desktop
Not seeing other stick of ram
posted by basslik on Jan 17, 2008
i just upgraded my ram in my compaq evo d310, both sticks are the same, 1 gig each, so now i have 2 gigs installed, but computer only sees 1 gig of ram?
and computer is running fine, but why doesn't it see the other gig?, i tried switching the memory sticks around, same thing?
Comment by basslik, posted on Jan 17, 2008
my computer supports 2 gigs.
slots are fine, tired different memory sticks, and they show right amount.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
courtdate
Rank:Wiz Wiz
Rating: 85%, 574 votes
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on not seeing other stick of ram:
I don't want to Accept this solution
Solution #2
posted on Mar 29, 2008
Not Rated (0)
acharyulu
Rank:Guru Guru
Rating: 85%, 38 votes
Hello
1. Check that ur M/b Supports that much capacity
2. Check the both sticks are of the same company and mb
If it supports do the following
1.  remove all the rams inside
2. Place the newly brought ram and restart the system
3. Check the system work perfectly
4. shut down the system and place the another ram and restart the system
5.  if it not works interchage the two rams and repeat the 2-4 steps
Let me know if your problem is solved and rate me as FIXYA!
Thank You!
Solution #3
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
thanks for getting back to me so quickly.
my model supports 2 gigs of ram?
i know the slots are ok, cause i tried different memory and reads in both slots"
Thank You!
Can you Help with these PC Desktops problems?
PC Desktops
How do I disable wireless capabilities on my modem
PC Desktops
The file "msvcr80.dll" is missing . I...
PC Desktops
I can't log onto my yahoo email account...I am getting a...
PC Desktops
I have a MY BOOKS ESSENTIAL EDITION. I can not get it to...
PC Desktops
my acer laptop screen keeps going dark because the rubber...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
