Question about Sharp SF 2314 Copier
My copier keeps flashing U-2 on the display window. What does this mean and hoe can I fix it so I can use my copier again?
Thank you!!
  • Sharp Expert
  • 257 Answers
Check and clean dirty chargers ie the main and trasfer ones and reset by pressing ; C,0,0,C in that sequence. The display will go out and enter 16 press Ready key to clear.
Posted on Nov 24, 2009
    President:
  • 2,072 Answers
A U2, is normally caused by the toner cartridge not communicating with the main board.
Try removing and re installing the cartridge a few times.
If that doesn't work try replacing it with a new cartridge.
The memory may have dumped also. In that case a new memory or main board would be required.
Posted on Jan 17, 2008
How do I fix the error code H4 that blinks continually on the display pane of my copier SF-750
if fixing the fuse unit by checking the thermostat and thermos-fuse then you reset the software by entering simlations by pressing # interpret cancel interpret press 14 start button
Sep 08, 2015 | Sharp Sf 750 Copier Fuser Roller Kit...
How do i fix c4 display by sharp sf-1025 copier?
It appears that the copier has a hardware error resolve it else repeated power-on will only damage it further
Jun 25, 2015 | Sharp Office Equipment & Supplies
Sharp sf 7900 copier, after paper jammed and removed the trouble shooting code light H-4 keeps flashing
HELLO
try to remove or unplug the power from the outlet and also same at the back of the printer and wait for 5 minutes and put it back on
just leave comments
thank you
Mar 15, 2011 | Sharp Office Equipment & Supplies
I HAVE A SHARP SF 2314 COPIER,I CLEANED THE GRIDY FOR MAIN CORONA WIRE NOW THE MACHINE PRINT BLANK;I USE MATHILETED SPIRIT.HOW CAN I SOLVE THIS PROBLEM?
MYA BE THE CORONA WIRE WAS SNAPPED AND IN ORDER TO PRINT YOU HAVE TO ASEMMBLED NEW CORONA WIRE.IF YOU WANT CKLEANED THE CORONA WIRE , JUST USE DRY CLOTH ,NOT WET IT WITH ANYTHING
Mar 25, 2010 | Sharp SF 2314 Copier
My copier flashes the L6 code and 10 when I hit print, how do I fix this?
Hello sir; The error code you display, that's means laser motor problem, need to replace it the item# is DUNTK0041RS52.
Sep 30, 2009 | Sharp AR-207 Copier
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
I have a Sharp SF-2022 copier and it flashes a U6 code abd will not work. How do I fix this?
u6 is sually something to do with the papaer tray or feed section check to make sure the tray is set properly and that you have the guide plates set correctly and that the tray is fully set
Jun 11, 2009 | Sharp AL 1631 Copier
I get f and 2 flashing
Hello sir; The code you display, means; wrong cartridge, please change to a right one.
May 20, 2009 | Sharp AR-M205 Copier
Sharp SF 2030 check sorter problem
follow the small holes on the sorter trays to the bottom and top there you will find the sensors that tell the copier that ther is paper in the trays make sure that they are clean and ther is no obstruction
Mar 24, 2009 | Sharp SF 2020 Copier
145 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
