Question about Onkyo TX-DS747
PROTECT thats all it says when I turn on my recevier. Is their anything I can do before I take it to a shop
Yes thats an easy problem to fix. when it says protect, that means two of the leads on the speaker wire are touching eachother. that means the positive and negative wires on it either going to the receiver or the end gong to the speakers. look at all of them. then if they were touching. take them away from touching and then turn your receiver off. then it will come back all ready to use. but if thats not the case i dont know what other reason it will be doing that. but anyways thats my theory of why its doing that!
Posted on Jun 05, 2008
    Genius:
  • 1,003 Answers
UNPLUG POWER FROM WALL socket 12 SECS AND REPLUG TO SEE IF THAT HELPS
Posted on Jan 17, 2008
6ya staff
SOURCE:
My techwood Str84 will turn on but only say protect
if it is in protect mode you have short parts that need to be replace.
Nov 10, 2012 | Televison & Video
How to remove write protect on a flash drive
open the flash drive and see if there are any settings. if you can't see any locks, see if there was a lock. i have a card that the lock is gone.anything more you find out will help you out.
Sep 06, 2012 | Electronics - Others
I get protect audio off when I turn it on
Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. I would take the unit in to a local repair shop and get a estimate of repair charges. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.
Take care.....
Oct 01, 2010 | Philips Magnavox MRD500VR System
When i turn it on it says protect and it turns off after that
Hope this helps.....
Jul 17, 2010 | Onkyo TX-DS696 Receiver
My kenwood 107VR keeps turning off on its own, after about 3 secs it shuts off and the light blinks.
If you are sure your speakers are good. This unit has a protect circuit keeping the unit from turning on. This recevier uses an ic instead of output transistors. A ic incorperates transistors,resistors,capactors in one assembly for size and costs. There is a number right on the front of the ic ,you can go on-line to buy the ic is is fairly easy to put in as long as you can desolder and solder in.
Apr 17, 2010 | Kenwood VR-209 Receiver
My reciever is blinkning 'protect' after being turned on. It starts up as normal but after the initial start it starts flashing 'protect' and after it starts flashing I can not do anything but turn it off....
It shows protect when it senses a problem with the output wires shorted or some internal fault. Try disconnecting all the speaker wires and power up again. If it still shows protect, then the fault is internal.
Mar 12, 2010 | Sony Audio Players & Recorders
When swicth on, it goes out after writing protect, can i do anything?
It goes into protect mode when it senses something wrong. First check the speaker wires for shorts or diconnect them as a test. Turn it on, if still in protect mode, the problem is internal and needs to be looked at by a tech/repair shop.
Mar 09, 2010 | Sony STR-DE497 Receiver
PROTECT MODe
reed the users manual...does it say anything about the protect mode ?
Aug 13, 2009 | JVC HX-D7 Shelf System
Monitor show " Protect " can't do anything.
Protect is an indication that one of the output amplifiers is shorted. The unit turns itself off to avoid burning more components. I'd recommend taking it in to a repair facility for replacement of the blown output amp.
May 04, 2009 | Sony STR-DE335 Receiver
I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
Onkyo TX-DS747 Logo
133 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
