Question about GoVideo VR3845 DVD Recorder/VCR
DVD Recorder+VCR I have ni problem setting this unit up, BUT IT will Not Function as Advertised! I am trying to convert VCR tapes to DVD's! Ther Tape will run through to it's program end, and stop. The DVD does NOT Record! Trying to start the process, the unit goes as far as 'Set up' on the readout. That is IT! I Can't get it to go beyond that so I can Record to DVD! WHY???
  • MikeTm Feb 21, 2008
    I have exactly the same problem. My daughter bought her Go Video a year or so ago and never could figure out how to make it record VHS to DVD. I figured I could do it. Bought my own. Does not work. I can read English, directions are not complicated. It simply does not do what it is supposed to do. Not impressed!
Are you putting in both media, starting the VCR you want to copy and then pressing copy? The first post mentions "set up" and that is not necessary for copying.
Posted on Feb 28, 2008
When I insert a tape, it is immediately ejected. it had been working fine until this evening.
Probably you are inserting a tape taht has it;s safe tab removed, and you unit is set to record.
Put some clear tape over the hole and try it.
Or try a different tape.
regards
Sep 04, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
When I place a vcr in my machine all I get is a snowy picture. Why would this happen? The DVD player works but not the VCR
Make sure the tape you are trying to view has something recorded on it. Also insure that the tape you are trying to view is not recorded at a speed your DVD Recorder/VCR combo can not handle. If it is a pre recorded tape and it will play on another unit, then your VCR heads are dirty. Try using a VCR head cleaner. If that doesn't work the heads may need to be cleaned by hand or possibly may be bad, a trip to the repair shop would be call for then.
Jul 01, 2010 | Emerson EWR20V4 DVD Recorder/VCR
How do I dub a VCR tape to a DVD. Also is the
You need a DVD recorder. Hook the VCR to the inputs on that and you will be set. Just put a blank DVD+/-R in, hit record, then hit play on the VCR.
If you don't have a DVD recorder you'd have to capture it into a computer and convert it to DVD format then burn to disc.
Oct 24, 2009 | Emerson EWD2203 DVD Player/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
DMR-EZ47VK Up-Converting 1080p DVD-Recorder/VCR Combo
I think the problem with the tapes stopping is that there is too much tension on the tape. Try another VCR and try to see if you have the same problem playing the tape. Forward and reverse through the part that causes the player to stop. It is also possible that the tape inside the vcr has become twisted or stuck. One can fix this if they are very careful opening the video tape. However, I would not recommend this for most people
Mike
Dec 22, 2007 | Lite On LVW-5045 DVD Recorder
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
GoVideo VR3845 DVD Recorder/VCR Logo
70 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
