Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Wierd colours have just had carbon monoxide alarm fitted this afternoon, in the middle of the ceiling, However tv wasnt on at time so dont know if it was this that has affected the colour etc, I'm getting a rainbow of colour and clear in the middle
  • tmwgardiner Jan 17, 2008
    thanks for your reply, its sorted itself out now
  • 2,039 Answers
Did you install or move speaker on the side off tv if yes the magnet in speaker do thatmove the speaker or antthing with magnet awaygive time it gonna come back like it was before cheers
Posted on Jan 17, 2008
What does it mean when my nighthawk carbon dioxide detector reads 14. It's right above my gas oven which I have on the clean cycle
I don't know what 14 means other than the display claims to show the detected CO level. You will need to read the alarm instructions or visit the Kidde website for further information, it will not be a carbon dioxide detector (CO2) incidentally, but a carbon monoxide detector (CO).
Siting the detector high and directly above your gas oven is not suitable. It could be placed on a table in a sitting area or fitted on a wall or even the ceiling, but again I suggest you defer to the the manufacturer's guidance.
Nov 15, 2017 | The Home Security
Can I mount carbon monoxide alarm on the ceiling?
I've read that the ceiling is the best place to put it. If you mount it on the wall it should be on open wall, not in a corner. Where ever the air can flow easy can be the best place.
Hope this helps.
Feb 26, 2015 | Home Security
How do I dispose of Carbon Monoxide Alarm & Fire Alarms?
If it's no longer working, just discard in trash. It doesn't contain any hazardous materials. If it's still working, then donate it.
Sep 23, 2014 | Kidde DC-Plug-In Carbon Monoxide Alarm...
Lost the tool that came with my Pro tech carbon monoxide alarm to change the battery
I discovered that a pair of pointy-ending tweezers (not the flat ones) worked perfectly. The points fit in the holes, and the tweezers could be squeezed to fit both holes at the same time. Why Protech decided that an ordinary phillips screw was not good enough is the subject of a whole rant...
Nov 06, 2013 | Protech 7035-SL Lithium Powered Carbon...
Are there any reported problems with the Firez 21007624 carbon monoxide detector false alarms?
I do not know of any reported problems specific to the Kidde CO/smoke alarm, but I spent a significant part of my career servicing toxic gas sensors and can give you some general advice:
1- Most important: treat an alarm as a REAL alarm and DO NOT suspect that your alarm is a "false alarm". My experience has been that most "false alarms" ARE REAL and the source needs to be identified! With Carbon Monoxide detectors, it is usually a blocked vent for a gas fired appliance- a hot water heater, furnace, or oven. Call your fire department or a service professional to make sure that there is no carbon monoxide. They have portable detectors that will be able to double check your alarm.
My advice to you at this moment is to act as if you have a real alarm condition and do not place you or others in a life threatening situation. Ventilate the room/ apartment/house IMMEDIATELY!
I will post more after I send this because you may be in a life threatening situation!
Mar 22, 2011 | Kidde Firex 21007624 Ac Carbon Monoxide...
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk carbon monoxide alaram is keep biping
Check your user manual for issues dealing with beeping alarms.
Your local fire department may be able to help educate you on the proper installation and use of Carbon Monoxide Detectors. A CO detector alarm should be taken seriously and you should follow the manufacturer procedures included in the package.
NEVER dismiss a Carbon Monoxide Detector Alarm for a malfunction.
ALWAYS treat an alarm as an emergency and follow manufacturer procedures.
Check our website for more industry information or for buying replacement Carbon Monoxide Detectors.
Jul 16, 2010 | Kidde Nighthawk Combo Gas/co Detector
Carbon Monoxide Alarm Beeps every 30 seconds 7 years old
likely the batteries are getting low, or you may need to replace it, otherwise i hope you dont have a poison gas in your home
Jul 03, 2010 | Kidde KNCOBB Basic Carbon Monoxide Alarm...
My First Alert Carbon Monoxide Alarm has failed
If the carbon monoxide detector chirps, the battery may be dead. New batteries can be defective. Check if the light is yellow when the alarm is chirping, it means the battery is low, replace with a new battery.
Warranty service information:
BRK Brands, Inc.
3901 Liberty Street Road
Aurora, Illinois 60504
For consumer inquiries call: 800-323-9005
Jarden Branded Consumables Canada
88B East ****** Creek, Unit 6
Richmond Hill, Ontario, Canada
L4B 4W2
Tel: 905-482-3720
Fax 905-731-8267
For consumer inquires call: 800-323-9005
If you are looking for new Carbon Monoxide Detectors, visit my website.
Oct 01, 2009 | First Alert Safety & Security Carbon...
Lost manual for the nighthawk carbon monoxide detector, model no.900-0082-00 made in 11/1996. hasnt been used for several years.DON'T KNOW HOW TO SET IT.
Hold on!
All carbon monoxide detectors have to be replaced after 5 years of manufacture date. The sensors are not reliable after that time and may give false readings.
A carbon monoxide detector is your only defense against the hazards of Carbon Monoxide Poisoning. I would never recommend installing a used Detector. Ask your local fire department for more professional advice on how and where you should install carbon monoxide detectors.
Visit my website for more information. Buy your next Carbon Monoxide Detector here.
Aug 13, 2009 | Kidde Low-Profile Digital AC Wire-In...
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
