Question about Motorola Mobility RAZR V3xx Cellular Phone
Dial out The phone will not dial out or menu operation
Sounds like the same problem as my phone. Thought it was moisture and dried out the phone and it came good.It stopped again and they replaced the keypad circuit board but its happened again . Looks like its back in for repair
Posted on Jan 24, 2008
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
Need to make sure DTMF tone is on - model 27903FE1-A I obtained some instructions and got to dial mode but could not get beyond as "Tone" was unavailable
Here is a direct link to the User's Manual for your GE model 27903 phone:
http://www.home-electronics.net/USER-GUIDES/27903_DOM_EN_CL_IB.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
The TONE dialing option is normally the default setting for any modern phone unless you have previously changed it to the PULSE mode yourself.
However, here is an except from the manual on how to switch between the two modes if necessary:
1. Make sure your phone is OFF (not in talk mode).
2. Press the Menu button to go to the main menu.
3. Press cid/vol (- or +) button to scroll to Setup BS.
4. Press Menu button to confirm and you may program the following items: LAC (local area code) and Dial mode.
Dial Mode
From the Setup BS Menu:
1. Press the cid/vol (- or +) button to scroll to the Dial mode sub-menu.
2. Press Menu button to enter the menu and use the cid/vol (- or +) button to select Tone or Pulse.
3. Press Menu button to save your selection.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 17, 2011 | Uniden Cordless Phone
I have an lg tritan and I don't like how my phone vibrates. Is there any way I can change the vibration pattern on my phone?
The vibrate is set by the phone and don't believe they changed But if the can is b in the hidden menu LG Tritan Information Menu a. From the phone dial pad dial b. #help*help (#4357*4357) LG Tritan Feature Menu a. From the phone dial pad dial b. ##Feature (##3328873) LG Tritan Service Menu a. From the phone dial pad dial b. ##LGSERVICEMENU (##5473784236368) c. Service code  000000 LG Tritan Programming Menu a. From the phone dial pad dial b. ##PROGRAM840 (##7764726840) c. Service code  000000
Jan 16, 2011 | LG Cell Phones
Phone dialing like rotary
Press the MENU button until TONE/PULSE MODE shows in the display. Press either arrow key to display the current mode. Pres an arrow key again to select TONE mode. Need the operating guide? You can download/print it here:
http://static.fixya.com/Manuals/G/GE/29385G1_Crdd_B46DA5B853306E0D4070DB3B7B910C90.pdf
Dec 07, 2009 | GE 29385GE1 Corded Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
Speed dial on a aLucent 642D+
Uucent are usually user friendly, so without the manual go on line, or failing that track down a phone number and get one of their operatives to help, its got to be about getting up the menu? Good luck.
May 01, 2009 | Lands Phones
It sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Jan 25, 2009 | Panasonic KX-TG1033S Cordless Phone
USB modem HiRo model H50113 will not complete phone connection
Yes you're right! What you have to do is:
  1. Right click My Network Places
  2. Select Properties
  3. Select the Advanced menu
  4. Uncheck "Operated-Assisted Dialing"
Jan 30, 2008 | Hiro V.92 56K AGERE Chipset PCI Fax Voice...
Motorola Mobility RAZR V3xx Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
