Wd1050fhb intello washing machine
Wont take a full load without shorting out the electric, and 800 spin does not light up? work! will only work on wool programe with VERY light load
  • 139 Answers
Most likely your carbon brushes are worn on the motor.. take of the belt and put on a fast spin program if it goes around then the brushes are worn on the motor hope this helps let me know if you need any other help...cheers
Posted on Jan 17, 2008
6ya staff
SOURCE:
It seems like our washing cycle goes all the way through to drain/spin without fulling draining or spinning - we have fabric softener left in the dispenser and the clothes are - particularly at the bottom...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | General Electric WJRR4170GWW Top Load...
Hoover 800 RLA washing machine spins slow or not at all.
It sounds like the electric motor is dying!
Either pay a serviceman to come in to confirm this or buy a new machine.
New motors can cost anywhere from $380AUD to $600AUD.
Jun 17, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Jan 06, 2008 | LG WD-16115FD Front Load Washer
Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Dec 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
