Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi DE6965 Hi i also have an al 3 error code does this mean it's the heating element?
  • Anonymous Mar 21, 2008
    hi , I have a Zanussi DE6965 and it keets coming up with AL3 Error message and stopping. What does this mean?
    hi - i too have same problem with AL3 flashing and machine stopping but don't know what it is. Watyer remains in the machine.
I had the same problem with my dishwasher. The fault is because the water is not heating but in the majority of cases I would bet that the problem is not with the element but with a burnt out track on the control PCB. I was advised by a zanussi dealer that this track being repaired will not fix the problem indefinately but looking at the PCB the track which burnt out is just the 240V live and switched live from the relay, therefore replacing the track (solder some wire where the track was to the pins of the relay) should fix the problem indefinately.
I have successfully repaired my machine, it has been working for a couple of weeks so far with no problems. A couple of tips:-
1. The relay/tracks in question are beside the two separate connectors at one side of the PCB close to the big 12V relay (it should be obvious as there should be scorch marks)
2. If the two separate connectors above are swapped on reinstallation it will appeaqr that there is no power so before removal of the wiring take a note (or picture) of orientation of the wires.
3. Do not attempt this if you are not comfortable working with mains voltages and ensure that all power to the appliance has been disconnected before dismantling.
4. To ensure a good solder joint clean the area before resoldering with switch cleaner, or just scrape any residue away if no switch cleaner/ IPA is available.
Good luck, let me know if this fixes your problem.
Kieran
Posted on Mar 29, 2008
MY dishwasher is not heating water
Posted on Aug 21, 2008
Why is my zanussi machine 6k9 1200apm error code e60
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty,
PCB faulty, wiring.
Dado
Feb 29, 2016 | Zanussi Washing Machines
I have a zanussi 6hg 1200 rpm it's flashing error code E 60 what does it mean
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Mar 24, 2015 | Zanussi Washing Machines
Model FDW80 error code AL-10 what does this mean?.
error code AL-10 == Failed heating element
You will need to have the element replaced, call a professional, or obtain a service manual and do a DIY?
May 12, 2011 | Hotpoint Dishwashers
AL 7 ?
AL 7or F7 is an error showing flow meter failure. The flow meter impulse wheel, found within the water tank in washer, is not working correctly.
Hope this help?.
Thanks.
Dec 04, 2010 | Zanussi 24 in. DE6965 Built-in Dishwasher
Al 5
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Oct 12, 2010 | Zanussi 24 in. DE6965 Built-in Dishwasher
Hi my dishwasher has an error code AL3 what can i do to solve this problem
The fault is because the water is not heating but in the majority of cases I would bet that the problem is not with the element but with a burnt out track on the control PCB. By looking at the PCB the track which burnt out is just the 240V live and switched live from the relay, therefore replacing the track (solder some wire where the track was to the pins of the relay) should fix the problem.
2. If the two separate connectors above are swapped on reinstallation it will appear that there is no power so before removal of the wiring take a note (or picture) of orientation of the wires.
4. To ensure a good solder joint clean the area before resoldering with switch cleaner, or just scrap any residue away if no switch cleaner/ IPA is available.
Apr 05, 2010 | Zanussi 24 in. DE6965 Built-in Dishwasher
I have an AL 7 code what is this and can resolve
Hi
As per the Service Manual, it Refers to Washing Motor Jammed.
Reasons :-
1. Motor Winding Short Circuited
2. Motor Winding Open Circuit
3. Motor Jammed by Foreign Body
4. Electrical Connections Detached
5. Tachometer Open or Short Circuited
Now,
You could try to Turn OFF the Power. Wait for few minutes, say 30 Minutes and then Try to Turn ON the Dishwasher. If Problem Still Persists, more often it is either Motor jammed or Faulty.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 30, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
AL3
Possibly tge heating element,I am having the same problem .When I check during the operation it appears that the water is not heating up. Only runs the rinse programme without the error message as I assume that uses cold water only?
Nov 21, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
416 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
