A collapsed hose will make the caliper stick. The inner part may have ruptured and the outer part of the hose is holding pressure on the caliper.
If your brake caliper's piston when in easy went installing brake pads then caliper's are ok, check front brake hoses, but 1st you need to pull code's from your ABS system with light on there's a code store in the ABS computer. Autozone can do this for free,
Your brake calipers need to be replaced.
