Question about Kenmore Elite 45986 Front Load Washer
Kenmore dishwasher "sensing" light
I pulled a dishwasher, about 5 years old, and moved it to a different location. Hooked everything up and wanted to give it a test run without dishes in the unit. Water fills properly and the sensing light stays on. Buzzing sound heard for a long time and then the dishwasher drains, without the water actually being pushed through the system to wash the dishes. Any idea what could be wrong or how to correct the problem?
  • 1 more comment
  • dpg7466 Jan 21, 2008
    SOLUTION: Catriver solved the problem. Thanks. I pulled the dishwasher and checked all of the connections. Sure enough, in the move a wire became detached. I plugged it back in and the dishwasher works great. Thanks Catriver, you saved me some money and time. Your rating is true, You are a Guru.
    dpg7466
  • Anonymous Feb 07, 2008
    My Kenmore 665 dishwasher goes to sensing, starts to buzz and then just stays there. Any suggestions. Water goes in, is hot and drains when we cancel
  • Ron Marek
    Ron Marek May 11, 2010
    dpg, Im not sure what model you have, I know it's a kenmore, some models have a start capacitor for the motor on the left side, see if in the move one of the wires came off the start cap. for the motor. Catriver.
    President:
  • 878 Answers
Dpg, thanks for the kind words, seen this many times, I had a feeling something came loose...Catriver.
Posted on Jan 21, 2008
I have a kenmore elite 665, and after a few minutes of "sensor", I hear a buzzing noise, and if it is the problem I have, it isn't normal. the motor is trying to turn, and can't, something is binding, next step is to pull it out from under the counter and attack the problem from underneath.
Posted on Jan 20, 2008
    President:
  • 1,314 Answers
The sensing light and buzzing are normal let it do that on its on then let me know what happens its a soil sensing light and is supposed to run a cycle on its own to clear it but lets see .we will go from there ok
Posted on Jan 17, 2008
We just moved into our house and are using a 4-5 year old Bosch dishwasher. It leaves a white film on everything. We use the recommended dishwasher detergent (Cascade powder) and Jet Dry. My wife is...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 11, 2011 | Dishwashers
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Aug 05, 2009 | Thermador DW44Z Built-in Dishwasher
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
White resido on my dishes
this is most likely soap residue try a different type
Dec 12, 2008 | Jenn-Air 24 in. JDB2150AWP Built-in...
I have a 2yr old Beko D2731FW dishwasher that has recently started to not wash things properly and leaving a gritty residue on everything. I run a dishwasher cleaner through it on a monthly basis and the...
Hello Senseless,
Although I am not familiar with your specific brand and model dishwasher, I can offer you some advice on how to clean things up.. First off, remove all dishes from the cleaning compartment racks.. then your dishwasher may or may not have a drain screen or filter near where the water exits that compartment to be pumped out.. rclean that filter thoroughly. Then run the dishwasher on its hottest cycle setting ( without dishes inside ) and after about 5-10 minutes..pause it and add in a cup or two of white vinegar then restart it.. Let the dishwasher complete the cycle and try washing dishes with it. That technique should cleanse deposits of components inside the dishwasher and everything should work as designed. I am assuming that you aren't getting any backflow from the drain system back into the wash area from the drain hose/pump and associated connections. If you are, you may need to give that plumbing a thorough cleaning too. Let me know if after you've tried this, you were successful.. If not, then I can provide you with a few other things that may help..
Regards,
Rick
Dec 04, 2008 | Dishwashers
"Sensing" Light
There is a relay on the soap dispenser, if it is a Kenmore quietguard 4, I had the same type of noise, the repairman replaced the dispenser, which to me made no sense, because the relay is activated from the control board. After the $130. for the soap dispenser, he ended up replacing the control board for another $160. Now the dishwasher only goes up to the dry cycle and stops. If you press the heated dry button and then the heated wash button 5 times each, the entire control face will light up and it will do some kind of reset and try a new cycle. I have tried the button pushing and it worked great till it got to the dry cycle, so I am looking for another solution without involving Sears. Good Luck!
Jan 17, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
1,084 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
