Back to:
Tags:
NEC MobilePro 900 Handheld
Critical error 678
posted by chanoc on Jan 17, 2008
I have a critical error 678 in my nec mobilepro 900 when connect the usb to my pc.
thank you for help to me
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 20, 2008
Thanks for Trying (70)
ellana2
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
plug usb connector into back of computer (not front)-worked for me.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on critical error 678:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rating: 0%, 0 votes
Plug usb into back of computer (instead of using front port). This fixed the problem for me.
Thank You!
Solution #3
posted on Jan 17, 2008
Not Rated (0)
ctf1800
Rank:Guru Guru
Rating: 85%, 3432 votes
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Thank You!
Can you Help with these PDAs problems?
hi i am looking for driver for NEC mobile pro 900, can you...
I think i read about this before I got my 900, but the...
when trying to link to my pc i get an error 678
I got the mobile pro 900 used from a friend and I...
Were you ever able to fix problem?
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
