Halecol i have a pavillion dv 4000 and it wont run off the battery even though in the power meter it indicates 100% it also registers as though it is charging. if i switch it on i only get the blue lights on the keyboard. it does work perfectly on the ac cable. any advice would be much appreciated
    Problem Solver:
  • 14 Answers
  • 4 Answers
1)try to check also if you'll see a solid GREEN LED light on your ac adapter.if yes, possible problem could be on the battery port or the battery itself
2)With regard to the battery meter,where did you find that?If not in the BIOS,try this.restart computer and press F2 several times .Once you're inside the BIOS.try to go to the battery option-try to see if the battery indicator would say 100% also.
3)if 100%,try another battery if you have one.use only the battery as the only source of power..if a known good battery works then the problem is with your old battery.if a known good battery won't work,that would mean that you have a problem with your battery port.if that is the case, you may have to replace your motherboard for that but if you still have an active hardware warranty on your pavillion dv 4000.try calling the manufacturer for a motherboard replacement and try asking also if your battery is part of any recall.
4)if the battery meter in the BIOS does not say 100%, try charging the battery for an hour then go back to the BIOS try to see if the battery meter would go up.if it increases the battery meter try using the battery as the only source of power...if nogo,go back procedure 3.
Posted on Jan 17, 2008
Battery Wont Charge Past 65%
There is a short-circuit happened at your laptop or the laptop charger.
Aug 12, 2013 | Computers & Internet
Unit is indicating that the battery on my Magellan 400 indicates dangerously low. How can I resolve this? The indash charger doesn't seem to be the problem.
i fix these 4000 and many other magellan gps daily so when considering my advice , please understand i do not google my solutions
assuming your car charger is working (the little green light is on) and your 4000 still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
this should help you....let me know if you need more help or info
bill
May 20, 2010 | Magellan Maestro 4000 Handheld GPS...
Computer dies FAST when unplugged even though power may register 100% befor unplugging also laptop does not seem to recognize battery properly . battery power goes from 100% to 35% overnight if unplug
You have a dead battery or the charging circuit is faulty. If you have had the battery since you purchased the laptop, then it is worn out and needs to be replaced.
Apr 23, 2009 | IBM ThinkPad A31 Notebook
It acts like the heads are dirty but they have been cleaned
4000 hours is not bad for a clean machine that is fresh
they reset the drum and capstan run time meters when the machine is serviced: so you can have circuit boards that are getting tired.. The boards have lots of Surface Mount Electrolytic Can Capacitors... the parts used are rated for 3000 hours of use at 100 deg Celcius.. they last longer as the temperature goes down..
they have a chemical inside that dries up...
so the machine may need overhaul.
but an old tape can cause this, a worn & dirty pinch roller can cause this also...
Mar 11, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Wont charge anymore? hp dv 4000
Does the computer acknowledge when you plug it in? Are there any status lights indicating AC power? If not then the electrical contacts in the laptop power plug may have broken. If you are not under warranty, you could take a peak inside the case where the connector is and possibly fix it with a soldering iron. In the meantime I'd backup any important data.
Jan 24, 2009 | HP Pavilion dv4000 Notebook
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
My laptop turns off in AC Power. Please help..
Windows 98 questions and answers AC, Additional help and information on autoexec.bat / config.sys. APM, Issues and help relating to Advanced Power Management.
Computer Power Supply Information WARNING: Do not open the power supply, it contains capacitors which can hold Electricity (WHICH CAN KILL) even if the computer is power off for a week.
Be careful , Good Luck, Please dont for get to Vote/Thank You.
Dec 26, 2007 | Fujitsu LifeBook B2131 Notebook
Wont turn on
i have the same problem,,
the battery its full and the camera no power on,,
help us!!!!!!!!!!!!!!
Dec 24, 2007 | Aiptek IS-DV Memory Card Camcorder
Computers & Internet Logo
106 people viewed this question
Alun Cox
David Payne
David Payne
