Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
HP LASERJET PRINTER #4250
I CAN'T GET THE OTHER TRAYS TO WORK
    Genius:
  • 1,003 Answers
GO IN PRINTER MENU ON PRINTER AND UNDER PAPER HANDLING OPTION AND SET OR SIMPLY SET PRINTER TO RESET FACTORY DEFAULTS UNDER DIAGNOSTIICS MENU
Posted on Jan 17, 2008
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
I am getting 60.02 error on my HP laser jet 4250 printer
this error comes from tray 2 lifter assembly check the wires harness of motor sitted properly in dc controller pcb
Sep 21, 2010 | HP LaserJet 4250 Printer
My HP LaserJet 4250 is printing my document margins off even when centered in Word?
check the tray amargin, or the paper sizeselected in your printer setting
Mar 22, 2010 | HP LaserJet 4250n Printer
Loading envelopes in an HP Laserjet 4250
Envelopes in the HP 4250 are loaded in tray 1 -- the pull-out tray on the front of the printer. Set the envelopes in and adjust the side guides, then go into the menu and set the correct paper size and type for tray 1.
Jan 29, 2010 | HP LaserJet 1020 Printer
HP LASERJET 4250 DUPLEX ISSUE
only problem ive had with the earlier model not doing duplex was a sheet of paper in the duplexer bin . This is hard to find but if you pull out the paper tray and look in the space where the tray goes up above theres a lever which you can push and it releases the hidden duplex bin which stores the paper at half way through the double pass and if there is any paper in there then the printer will not duplex.
Oct 02, 2008 | HP LaserJet 4250n Printer
HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
HP laserjet 4250 evelope smudge
What kind of trouble are you having?
ie.
is it jamming is it making noises???
4250 n ,nt dtn?
Feb 05, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
