Question about Sony Cyber-shot DSC-W80 Digital Camera
CANON POWER SHOT
CAMERA LENSE WON'T CLOSE AND RETRACT
  • lalalauren08 Mar 30, 2008
    same problem. lens will go out but not come back in.
My camera lens has opened but will not close and retract.
Posted on Sep 15, 2008
The Lense will not go back in
Remove the batteries from the Camera. Then press and hold the power button down for 45 to 60 seconds. Replace the batteries with new ones and install them in the camera. Then turn it on and wait until it finishes its normal warm up, then press the power button to turn it off. This should make the lense retract back to normal position. If the lens does not retract, contact the manufacturer for assistance with repair work.
Jul 07, 2011 | Canon PowerShot SD1000 Digital Camera
My Canon Power Shot A1100 IS camera fell and now
There is no DIY fix for this problem, and attempting a fix is likely to worsen the problem and cause the camera to shut down. Sorry, but your situation calls for professional repair.
Oct 31, 2009 | Canon PowerShot A1100 IS Digital Camera
Lense will not retract
Try to move it manually. If not succesfull, I am afraid you have to let lens replace.
Sep 19, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Canon Power shot lense will not close
THE PROBLEM IS THE LENSE WILL NOT CLOSE ON THE CAMERA CAN YOU SOLVE IT PLS MY EMAILL IS[ CD1DJ24@HOTMAILL.COM ]
Apr 29, 2008 | Cameras
Lens stuck
Solution:
The Lense is obviously jammed some how.
Suggestion:
Send the product back to the manufacturer and see if they can repair the product or send you a new one.
Dec 18, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
