Display i have a pic of a speaker with a red cross through it on the left hand side top of my screen and dont know how to get it away
  • 1,003 Answers
Turn mute function off
Posted on Jan 17, 2008
The red exclamation mark and the green setup light remain on.
I experienced the same problem several years ago and tried the suggestion provided below. It worked and it is still working today.
Here are instructions posted by John Phillips on ""
Steps I took - and it worked beautifully - display problem solved !!
1. Ease off the plastic facia that covers the control buttons - (no screws - it just clips on)
2. Remove the cross head screw that is seen to the bottom left of the display unit.
3. Flip display unit open - remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!!
4. Remove the display unit - unscrew the 4 small cross head screws that hold the display assembly together - NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE - I didn't make a note at first, and it took me ages to work out where it went when trying to re-assemble it !!
5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block - Re-assemble merely by pushing it carefully back into place.
6. On the circuit board you will see a large (ish) black Integrated Circuit - using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit.
7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals
8. Having a soldering tip small enough is vital if you are to attempt this - an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary "Twin and Earth" electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point.
9. Re-assemble - switch on - and if you have been careful and succeeded in this feat of micro soldering - you should have a realistic chance of having a fully functioning display once again.
Jan 08, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Small phone icon with red cross on it?
you sure it''s a cross and not an upward arrow? If it is you''ve just missed a call
Dec 10, 2008 | Sony Ericsson K800i Cellular Phone
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Blue screen red lock
I dont have a clue what happened...
The screen is blue and has a little red lock on the upper left hand side...
remote only works to turn it other buttons work.
Help please!!!
Apr 01, 2008 | Insignia IS 20" TV040919 TV
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Accidently locked tv
Sorry but you're going to have to be a bit more specific than that.. What kind of Tv is it, what model number, is it the original remote, do you have an otherwise good pic and sound, do functions (vol, ch, power) on the Tv work???
Dec 11, 2007 | RCA 20F514TD 20" TV
When in the auto setting, press left (I think - if not try up, down or right) on the circular button... this well amend the logo on the left hand side of the screen, One is like a bolt of lightning with 'a' for automatic, crossed out for not at all, and the sole bolt of lightning is premantly on. Using the up button on the circular button (or alternative) will amend the red eye light on or off. Turning this off will enable to take photo's quicker
Dec 05, 2007 | Samsung Digimax S730 Digital Camera
Noise in my speakers
you need to go to asio config and open the controls tab and mute the first two channels on the left hand side you will hear your music without the humming noise.
Oct 18, 2007 | AudioTrak MAYA 44 USB External Sound...
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Red Lines On Screen of Hitachi 43FDX01B
can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Apr 11, 2006 | Hitachi THE SOLUTION 3511 Projector, Mount...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
