Question about Mitsubishi WD-62525 62" Rear Projection HDTV
My mitsubishi tv won't turn on - Mitsubishi WD-62525 62" Rear Projection HDTV
  • Mitsubishi Master
  • 8,617 Answers
Bad capacitors that chassis is famous for numerous capacitors failing without notice.Every circuit board within the entire chasis will have numerous capacitors that will be swelled up and leaking which will require that they be replaced. You can get the repair kits for the V26 Chasis at www.tvrepairworld.com which contain instructions on the CDs along with the replacement parts.
Posted on Dec 05, 2009
SOURCE:
Mitsubishi tv 32 inch model number cs40505 won't turn on
Check its power regulator board. Check fuse. replace it as card basis, if found irrepairable.
Jun 14, 2012 | Mitsubishi CS-40505 TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
WD-65734 Mitsubishi TV won't turn on. System reset does nothing. Fuse OK.
Does the front light blink a pattern. If so this may be used to lookup the error codes.
Aug 26, 2011 | Mitsubishi Televison & Video
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
My TV won't turn on - it was working fine when I turned it off and now it won't turn on...
have you checked the fuse at the back??...this just might be your problem. It is located on the power supply side of the motherboard.
Good luck and thanks for using Fixya.
G..
Jun 29, 2011 | Mitsubishi WS-48613 48" Rear Projection...
Timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
Jul 06, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
218 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
