Question about Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point
Configure cisco aironet wifi
Kindly help in configuring the cisco aironet1200
now i connected console via hyperterminal in winxp
thanks
Ravi
    Problem Solver:
  • 5 Answers
If ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Posted on Jun 19, 2008
6ya staff
SOURCE:
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
How to configure cisco aironet 1131 and how to find the getaway for this router ?
Have you read the quick start and installation guides?
http://www.cisco.com/en/US/products/ps6087/prod_installation_guides_list.html
Yes, the AP should be able to obtain an IP address via DHCP from your
Netopia router.
If this device is used, it may not be setup to aquire things via DHCP,
and you'll probably have to hookup over a console port and do password
recovery.
Cisco's aren't the easiest things to setup, they are more akin to a
box of tools, rather than a single purpose built item, and thus can
do quitealot, but you have to learn how to use the tool first. It will
then let you setup things quite advanced that the single-purpose built
item never imagined, but you have to know how to get there first, not
coast and do the advanced stuff later.
Dec 29, 2013 | Cisco Air-Ap1131G-A-K9 - Aironet 1131G...
Reset cisco aironet 350 adapter
Try Putty and a 9pin male to RJ45 RS232 serial console cable.
the instructions are in the link provided here:
http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Computers & Internet
Hi Sir/Madam, I have an issue on cisco Aironet 1142n, keep connecting disconnecting sometimes only, i have configures 4 Vlan's and 3 ssid's, any one can help me to solve this issues. if more...
This might help:
In Device Manager, open your wifi and/or Network Adapters Properties, under Power Management tab, disable the "Let Windows turn off this device to save power".
Feb 19, 2018 | Cisco Aironet 1142N (AIRLAP1142NIK9)...
I want to update the IOS on a CISCO Catalyst 2950. I'm connected via console:serial to my Windows 7 Ultimate machine. I've also got PuTTY installed. The internet is being routed thru a Linksys NR041. What...
Please check whether the console cable is connected properly.
use Hyperterminal to configure the router.
Select the ISO image location in the computer and use the appropriate commands to copy it to flash.
Jan 22, 2011 | Linksys Computers & Internet
How to use hyperterminal
Run HyperTerminal in Windows by going to Start > Programs > Accessories > Communications > HyperTerminal.
After clicking on the HyperTerminal icon, you will see this window:
HyperTerminal prompts you to create a new connection. Note that this is not required but let’s go ahead and do it.
Type in the word cisco for the connection name and click OK.
Connect your Cisco device to your PC’s COM1 port but don’t turn it on yet. On the next window that appears, make sure that the “Connect Using” field says COM1 and click OK.
On the next window, change the Baud rate to 9600 and click OK.
Now, turn on your Cisco device. In the HyperTerminal window, you should see the boot up process for your device, like this:
//'); //]]> document.write(''); CollectiveMedia.createAndAttachAd("ns-74737014_1271195234","http://ad.doubleclick.net/adj/ns.petri/archive;net=ns;u=,ns-74737014_1271195234,11286e7f1d8af7d,ce_mobile_blackberry,;;kw=;tile=2;ord1=504214;sz=300x250,336x280;ppos=BTF;contx=ce_mobile_blackberry;btg=;ord=3760843785557546?","300","250,336",false); archive;ppos=btf;kw=;tile=2;sz=300x250,336x280;ord=123456789??\ You have successfully configured HyperTerminal and connected to your Cisco device.
When you are done and try to close out HyperTerminal, you will be asked if you want to save this connection. I suggest saving it with the name you gave it, cisco, so that you don’t have to configure it again next time.
Apr 13, 2010 | Cisco Aironet 1142 (AIR-LAP1142N-A-K9)...
Can't get email when connected to WiFi network
Your pop account settings might have to be changed.
Apr 10, 2017 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point Logo
1,578 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
