Whirlpool wont spin or drain...
My whirlpool llr9245bq1 wont spin or drain when in the spin cycle it just makes a humming sound but nothing happens..what could be the problem..p.s i removed the clothes so now its just water in the machine and it still doesnt work...
    President:
  • 1,314 Answers
Something is jamming your drain pump Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub.Rmove the spring clamp pull the hose now you may or may not have to replace the pump depending on if you can remove the object.
Posted on Jan 17, 2008
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Sep 14, 2017 | Whirlpool WTW5100S Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Oct 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
