Frigdaire Electric oven model FEF352AWE oven will not heat at all.
Hello there:
This conditin is usually caused by a faulty element and or the relay for the element is bad and also the temperature setting switch could be faulty
so what i would have to suggest is to have the heating element replaced first cause the temperature switch rarely fails ok
If you still; have the warranty with this oven i would use it the element is going to cost around 50 dollars or so ok
Best regards Michael
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing
the Igniter
heatman101
Hi. I will need more information on this issue. i need to know if the unit is powering up, and if the main control board is operational. If there are any error codes being displayed, please be sure to post them. Thanks:)
