Question about Refrigerators
Drain plugged in freezer
Thank you for your help.
I think I have 2 distinct problems.
In the freezer compartment of my side by side, there is a drain below the coils. This drain seems to be plugged causing water to run into the compartment and ice to build up on the bottom.
I'm guessing this leads to the tray on the bottom and is supposed to evaporate.
Is there a way to "unplug" this drain?
The second problem is also in the freezer compartment.
Chunks of ice build up in the coils. This reduces the performance.
What we have done is take a hair dryer and melt the ice.
But how do we stop the ice build up in the first place?
Thanks, again.
Larry Foster
  • 4 more comments
  • LarryFoster Jan 17, 2008
    Sorry.
    This is a Maytag PSD2450GR side by side.
    Larry
    Thanks for getting back to me
    The build up in the coils is ice. But the coils are very frosted, too. Not sure if they should have frost or not.
    I think the problem with the ice build up on the bottom of the compartment have to do with the drain not working that is located directly under the coil.
    Thanks
    There are large chunks of ice forning in the coils.
    In addition to the large chunks of ice, the is frost on the coils.
  • donna1234 Feb 20, 2008
    have same problem with dacor, i think its a problem with the drain freezing up because of improper insulation on drain pipe or warm air intrusion from refridge side. how do you get to freezer coil compartment i want check pan
  • GEBO Apr 14, 2008
    ON FREEZER SIDE, HAVE THICK SHEET OF ICE ON BOTTOM HAVE SEEN THE WATER COMING FROM VENTS ON BACK PANEL AROUND WHERE THE BOTTOM GLASS SHELF IS. WATER THEN LEAKS OUT OF FRONT DOOR ONTO KITCHEN FLOOR. MADE BOTTOM BASKET STICK AND HAD TO THAW OUT WITH BLOW DRYER. MAYTAG MODEL# PSD2450GR* WHITE SIDE BY SIDE ABOUT 3 1/2 YRS OLD. ALSO IS THERE ANY FILTERS ON THIS MODEL?
  • Anonymous Mar 26, 2014
    suddenly started getting a large build up of ice crystals in freezer compartment. Defrosted with hair dryer but started to come back again.
  • 90 Answers
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Posted on Jan 17, 2008
  • Douglas Woods Jan 17, 2008
    If its just frost on the coils then you have a defrost problem, but if you have ice with a little bit of frost on coils, most likely caused be leaky valve.
    Frozen drain just needs to be thawed out. Boiling hot water does the best.
The top freezer compartment drain hole ices over and freezes up and then the moisture goes down into the refrigerator and accumulates under the crisper drawers. This is a frost free fridge.
Hi and welcome to FixYa. I am Kelly.
The compartment drain is most likely clogged somewhere other than the funnel in the freezer compartment. Often what happens is the very end of the drain tube in the very bottom of the unit at the drip pan gets coated with lint and gunk. It then dries off and makes the perfect PLUG. Here is what I recommend you do:
1. Unplug the unit and do a manual defrost by directing an external fan into the freezer compartment for just over 2 hours with the contents removed. It takes this long because the water in the drain funnel acts as an ice insulator and you have to get it above 33F.
2. While the manual defrost is in progress remove the fiberboard rear panel and access the drip pan. Make sure the very end of the compartment drain is cleaned off. Clean out the drip pan also. These can get very nasty.
3. At the end of the 2 hour manual defrosting period... use a vacuum on exhaust and direct air into the RND of the compartment drain tube. Your trying to float out and debris from the drain funnel in the freezer compartment. Have someone listen for air-flow in the freezer from the ddrain funnel if possible.
4. Reinstall the rear cover and return the unit to normal service.
This works most of the time. However if there is a pinch or a kink in the compartment drain tube somewhere the problem can easily repeat.
Thanks for choosing FixYa,
Kelly
Jul 02, 2011 | Refrigerators
Leaking on floor freezer side
Hi and welcome to FixYa, I am Kelly
Without a model number this will be a very generic response. Most likely your evaporator drain is clogged with ice. You must do a manual defrost by unplugging the unit and doing a manual defrost with a fan directed into the freezer compartment for just over 2 hours (Water mess so be prepaired) The reason you do it for 2 hours is so that the ice in the drain funnel will melt. After the 2 hour period and tending to the water mess.... open the back of the unit by removing the fiber-board cover. Find the end of the compartment drain tube and make sure it is NOT blocked. Take a vaccum and direct pressurized air up through the drain tube to float out or clear any debris in the drain funnel. Have a 2nd person listen for air flow up through the freezer compartment drain. Once you are sure the drain is clear.... clean out the condenser coils while you have the back open and then reinstall the fiberboard cover. Just make sure the drain tube END is in the drip pan before closing the rear panel.
If you do NOT ever hear air flow up through the freezer compartment drain... you will have to remove the evaporator cover and dig out the debris.
Plug the unit back in and return it to service. If you have a repeat of the dripping water... respond with your model number and I can tell you what you need to check.
Kelly
Feb 16, 2011 | GE Refrigerators
Why is my Samsung two-door fridge freezer leaking water into the bottom of the freezer compartment. What is the solution. I have defrosted it for 24 hours without success.
Hello there
You said you' ve defrosted it for 24 hours, that is good and it is the first step, Now clean out the drain system on the freezer side. The ice melts and become water it should drain out onto the drain pan underneath . But because the drain is plugged and the water can't running down the drain so it running out the drip pan onto the bottom of your freezer compartment. You may need to take out the back pannel on the freezer side to get to the drip pan below the freezing coil.
Hope this can help you to solve the problem.
Dickson
Nov 04, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Approx. every 6 mo. I get water on the floor beneith the freezer side door. It seems to require removing the freezer contents and the back panel of the freezer compartment, exposing ice plugged drain. How...
Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leakage from bottom of upright freezer, on side by side fridge/freezer combination.
most unit have automatic defrost that melts ice off coils in freezer compartment it is on a timer sounds like the drain line has plugged or frozen to verify unit will need to be dismantled and verify drain clear
how ever if problem is just ice unit can be emptied and allowed to thaw completly and then turned back on and refilled if problem reaccurs then drain was plugged first and then froze normally I would thaw unit and pour water down drain verify clear before restarting normal defrost cycles it will leak about the same time everyday good luck ron
Dec 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
I have a top-mount refrigerator that is leaking from the air vent
I had the same problem with a whirlpool refrigerator with freezer on top. TURN OFF & UN-PLUG IT. To access the freezer drain you must pull the refrig out from the wall and take off the bottom-back panel, it uses some (7) small nut headed screws. The drain is the white tube on the left going into the drain pan. You can push a long wire or plastic hose up the tube, however that will probably only hit something solid (ice) and blowing air may not clear it, until you let the freezer completely thaw out, which may take several days. The following may help experienced do-it-yourself nuts, it is not for the faint of heart! I took out all the freezer items and placed them in coolers to keep them frozen. Then removed the back panel in the freezer, two nut headed screws at the top center. The bottom of this panel was frozen to the bottom of the freezer compartment, so I used a hair-dryer to thaw it enough to loosen it. (Be careful: water and electricity do not mix well!) The left side of this panel has some electrical control wires attached, so the left side will not come out, just rotate the panel and lean it against the left side of the compartment. Now use the hair dryer (or pour hot water on it) to melt the ice along the bottom back of the compartment under the freezer coils. BE CAREFUL: The fins are sharp and will cut! Do not bend them. If they are all frozen up your heating element-defroster may be out. If there is only ice along the bottom, the hair-dryer or hot-water will help melt it to the point it can be removed. If the drain hole at the back-bottom-center-right is plugged with ice, poor hot water on it to speed up its melting. The hair drier will not do this very fast and you cannot chip it out without damaging the plug hole. Mine was solid ice about 2 inches into the tube and hot water finally thawed it. Then pour water through the hole to flush it out. Clean the bottom drain pan & re-assemble. Good luck.
Dec 16, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine out...no more puddles on the floor.
Feb 04, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
658 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
