Printer I have an HP Business Inkjet 1200 Series. The color cartridges show full, though the color print quality is quickly deteriorating. All color is coming out in primarily the magenta color. I replaced blue cartridge and no change. I went through the three step cartridge head cleaning process – did improve a little, but still very poor quality. I do get the lines in the colors as well.
    Sniper:
  • 62 Answers
The cartridge needs cleaning. There are several things you can try. Using a wet paper towel, you can wipe the gold portion of the cartridge to try and draw out ink, or you can dunk the entire cartridge in warm water for a couple minutes or so (I have done this with success). The process is more clearly explained here:
http://www.usainkcartridges.com/faq.html
Posted on Jan 18, 2008
How do I insert new cartridge into HP desktop 1510
Easy answer , though this here isn't your answer but try googling it or you tube. I've always found answers there.
Good luck !
Jan 02, 2015 | HP Deskjet 1510 Inkjet Multifunction...
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Have color cartridge in, bottom tab removed and printer will not print in color
Print quality issues could be due to clogged cartridge nozzles. Please follow the steps below to clean the print cartridge nozzles:
  1. On your computer, go to Start > All Programs / Programs > Lexmark 1200 Series > Lexmark Solution Center.
  2. From the Maintenance tab, select Clean to fix horizontal streaks.
  3. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them.
  4. Try to print again.
Jul 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
My HP 1000 Photo Smart is not printing in color. The film has been removed from the new cartridge, the printout shows color, grayscale is not checked Where else do I need to check
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 10, 2010 | HP Business Inkjet 1000 - Printer - colour...
My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Nov 16, 2009 | HP Inkjet 1200dn Printer
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
C7180 Print in color without all cartridges
You can usually print with an empty cartridge, even though the software will inform you that the cartridge is empty. Your print quality may be affected, however.
Dec 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
