Question about Panasonic KX-T7730 Corded Phone
Phone poltergeists Hi We have 7 handsets. For the last couple of weeks, 3 of these have been randomly ringing or bleeping for no reason. For example, phone 1 - the speaker phone light come ons, phone 2 - auto dial/ store button lights up (display reads pitts program no) and phone 3 has cut two calls to clients off mid conversation - one client said he was told he was on hold, but line just dropped our end. This phone also has the auto dial/ store button and intercom button light up (display reads pitts program no). None of these are the programming phone. Originally thought cleaner had pressed something accidently, but can't figure out what. Please help
    Scholar:
  • 146 Answers
Here is a link to the operating manual which may help.
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
with strange anomalies, it is sometimes best to clean the system.
Suggest you go back to factory default settings by unplugging each phone for about 10 seconds then re-connect. also with main phone switch off power for 10 seconds and switch back on.
Posted on Jan 21, 2008
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
Setting number of rings before answering machine kicks in
Probably a cordless right?If it is,there should be a function button on the handset.Without pressing to dial out,press or hold down the function button.If there is a directional type button,you may have to press down or keep pressing the function button to cycle through the options.Once you find the ring set,it will probably require the directional button up or down to change the number of rings.Function could also be on the base,but it's usually on the handset.You may have to play around with a couple other buttons if there is no directional button but most seem to have the directional button these days. Good luck!
Jul 22, 2010 | Uniden Lands Phones
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
Hi.
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 | Cell Phones
Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Oct 06, 2009 | Philips Lands Phones
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Oct 05, 2008 | Philips DECT 2151 Cordless Phone
Brother 1840 bleeps
Try to unplug the handset and try again.
Unplug the phone cords from any shared devices.
Do you have DSL or any other digital type phone line?
Make sure the phone cord is plugged into the LINE port of the fax machine.
Jul 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Problem with Audio on Handset
that mean you handset speaker have problem change the speaker or buy new phone for more happy moment
Sep 13, 2007 | Nokia 6133 Cellular Phone
No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Jun 28, 2007 | NTL VS1500 Cordless Phone
Panasonic KX-T7730 Corded Phone Logo
116 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
