Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Very noisy the up right has recently become very noisy
  • 1,673 Answers
Usually when the motor fan or motor bearings go bad, it will run very loud. You will have to replace the motor. Part #2031214, sells for around $55.
Posted on Jan 17, 2008
My S7580 vacuum cleaner is very noisy
Hey, this is Jeremy with Crucial Vacuum,
To remedy a noisy vacuum cleaner there are typically four main areas to check to restore proper functionality. By following the steps below it should be back to normal in no time!
1. Dirty Filters- If your vacuum has suddenly become very loud, check the filter, as it may be dirty. When the filters on a vacuum become excessively dirty, the vacuum may start running louder because it is working hard to create suction. If your filters are dirty, your vacuum is likely not suctioning appropriately, either. To fix this problem, simply remove the filters in your vacuum, rid them of the dust and debris and rinse them out with warm water.
2. Clog- Clogs are often the reason as to why your vacuum cleaner is being extra noisy. While vacuuming, something may get sucked up such as a button or a small toy, for example. Additionally, the clog may be making the vacuum work harder. Check all tubes and hoses in the vacuum to make sure there are no obstructions.
3. Broken Brush Bearing- When a brush bearing breaks, the vacuum cleaner gets loud and starts to vibrate. To remedy the problem, remove the brush and replace it
4. Broken Fan- The fan in the motor of your vacuum may be broken, causing the vacuum to run louder than normal. When dirt runs through the motor of the vacuum, it can collect on the fan, causing it to break. If the fan in your vacuum motor is broken, it will need to be replaced. This is a slightly more tricky process and may require you to bring in your vacuum to a repair shop to have the part replaced.
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 09, 2015 | Miele Vacuums
The motor on my Bissell 10N6 SERIES vacuum cleaner has become very noisy and the motor is running at very high revs. I have cleaned all filters, pipes, brushes etc but it has not solved the problem. I
mine did the same thing , its a internal problem inside the motor and is gradually burning the motor up. I would suggest you start looking for another one
Feb 05, 2015 | Bissell Vacuums
Noisy hoover
1 Check the impeller to make sure it is not missing part of a blade or has something jammed in it that could throw it off balance.
2 Check the bearings on the rotating brush, especially at the belt end.
3 Remove belt and turn on. If noise still persists, it likely would be the motor is shot.
Jun 21, 2014 | Bissell Lift-Off Floors and More Pet...
When the vacuum is turned on it is a lot louder
The fan in this machine can become out of balance. The fan needs to be replaced even if the blades are all there.
Dec 01, 2009 | Oreck XL2000 Bagged Upright Vacuum
Not so quiet anymore
If the filters was very dirty, you might have got some dirt in to the motor, best to have it checked
Dec 17, 2017 | Bissell Upright Vacuum - The Pet Hair...
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
The newer models have plastic end caps that will melt when the bearing heats up. This will cause the cap to go "off-centre" and the roller will vibrate badly. If this is the case, you will have to replace the roller.
If the belt is a geared drive, check the belt for any missing teeth.
Jan 30, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
High rpm
These machines are noisy to begin with, but will become worse if anything is allowed to enter the fan area of the motor. I have seen debris clog the front fan and put the motor out of balance so it will really scream when it runs. This work is best left to a competent professional
Jan 11, 2008 | Hoover Portapower C2094 Bagged Canister...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
308 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
