Question about Sony DSR-45 Mini DV VCR
Tape is not threading
When the tape is loaded. its not threading ... what should i do ???
    Genius:
  • 1,139 Answers
Hello haroon2008,
Check to see if the gear or wheel is engaging the capstan.
This more then likely is your problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 17, 2008
Need an Eicor 1950 Home Tape Recorder and Player repaired. Local to Washington, DC Metro area.
That is; supply wheel turns, and take-up wheel doesn't. Isn't it? The tape deck mechanism fault. Should be a broken belt [loading belt] can cause this. Check for it.
Nov 29, 2015 | Audio Players & Recorders
Vcr keeps turning off by itself. can't load tape.
Take the top cover off & have a look at the deck mechanism to see if there is anything obstructing the tape from loading properly. Put a tape in & watch closely to see if it draws the tape in, lowers it down & then threads the tape around the heads. If this is not the case & there is nothing in the mechanism preventing this action then look to see if the head drum is spinning.There may be a fuult with the loading motor if the tape is not being pulled into the machine. If there is a fault with the deck then it is best to take it to a repair centre.
Jul 15, 2009 | Daewoo Televison & Video
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Oil leaking from thread of oil sensor on ef falcon.
Possibly,the sealant used should be the white teflon that comes in tape form or as a liquid in a small squeeze bottle.The liquid form,you would want the threads free of oil,the teflon tape,oil present doesn't matter,although the tape should be applied to the threads in the opposite direction of the threads.The threads would screw into the block clockwise,so apply the tape from the counter clockwise direction.It is also possible that the sending unit itself has a small crack somewhere,and these sending units aren't all that expensive,so i would install a new unit while using the teflon.
Nov 04, 2008 | 1999 Ford Super Duty F 450
My Panasonic NV-SD270 video player wont play or release a video cassette and shows the error message "F05". Does anyone know what this means? thanks Chris
when the loading mechanism have a trouble and did not thread the tape properly , the eject mode commands primarily coz the tape in sensor activated properly
Apr 29, 2008 | Televison & Video
Tape Playback
check the end sensor
Mar 30, 2008 | Sony VO-5850 VCR
Hello optasia,
I hope this helps,
Thank you,
Shuttle83
Mar 07, 2008 | Sony DSR-45 Mini DV VCR
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
Flashing "2" on VCR front panel.
Hi Oshaman. I have dealt with many VCR's and would like to ask you a few questions before diagnostics. How exactly did you get the tape out of the machine ? There are several tape threading gears involved, and if you accidentally made one of them skip a few teeth while forcing the tape deck up the "position" switch will send erroneus signals to the tape threading position switch/ controller. Was the tape rolled around the capstan/pinch roller ? Did you have to force the tape loading tray up to extract the tape ? Feel free to email me. pemere@optonline.net. Happy Holidays.
Nov 11, 2006 | Samsung SV5000W VHS VCR
Sony DSR-45 Mini DV VCR Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
