What is the cause for the pc-d320 canon copier to print dull
My canon copier has a new catridge but is printing dull after I have service it.
What could be thew cause ?
also there is another one that is printing black can you please advise me.
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section pifonski
* The first reason has to be the Catridge without ink.
* The second reason has to be Catridge not fixed properly.
* The third reason it has to be problem with the Paper slider getting stuck because of dirt and dust.
If internally generated prints are good, but copied documents are bad then your scanner needs cleaning. This can be found in the document feeder section where the light scans across the paper. If both copied and internally generated prints are bad, then chance are, your toner/drum catridge has run out.
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
hi im jules_09,check the developer,if its past over 60,000 copies if
its over 60,000 copies you need to change the developer along with the
opc drum and cleaning blade or roller,all copiers need to be replaced
with new developer,opc drum and cleanign blade or roller when it reach
its copy life,that may be the cause of light copy of print
