Question about Panasonic KX-T7453 Corded Phone
No Light to show off hook
I had someone switch desks. I moved their extension number to a different jack. The only thing that doesn't work is when he has his phone off hook, his extension doesn't light up on any other phone to show it is in use. I don't know if it has to do with moving the extension to a different jack in programming or not. Thanks!
    Problem Solver:
  • 14 Answers
Start by going to the phones that need to have the button fixed.
Press:
[Program], [9][9], [Button] (you should see an incorrect ext number), [2], [Correct ext number] and [Store]
You may need to repeat this at all phones that need the corrected light.
Posted on Jun 27, 2008
I have a NEC DTH-8D-1 Corded phone. I moved my desk and plugged the phone in at a different phone line port and the screen now reads "Initialize." What is it asking for? How do I set up my phone at th
Your extension is hardwired to 1 jack, if you plug in somewhere else you'll be lucky if the jack is active with another extension. Someone needs to re-wire your extension in the phone room to your new jack. If it won't activate but says Initialize, then that jack probably has a live fax line or analog extension, but not a digital line that works on your phone.
Sep 02, 2014 | NEC DTH-8D-1 Corded Phone
M7208
The only way a password will stay with a phone is if the "Extension Relocate" feature is turned on. This means that when the phone is moved from one desk to another it retains the same extension number. To verify this do a Feature *0 and press the intercom button to view your extension. Now move the phone to another desk and repeat the process.
Passwords are related to the voice mailbox and there are verbal commands using the dial pad to make any changes. Usually 1 is for yes and two for no or 1 to change and 2 to accept. Not knowing which voice mail system your have it is hard to give anymore detail.
Jan 28, 2014 | NorStar Lands Phones
Our phone system crashed not to long ago and had to get new equipment we had someone come in and reprogram the phones. Everything was fixed except a few extension were switched around. so say the person at...
Go look at the system cabinet. The processor (the card with all the jacks in the center) are numbered. If it's an R8 card, then they number 10-18 from left to right and top to bottom. (actually 10-14 and 15-18) 13 and 17 are right next to each other :-)
It's fairly easy, you ought to be able to start moving jacks and figure it out.
Carl
Jun 01, 2011 | Lucent PARTNER18 Corded Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
How do i change the phone extention number - Panasonic KX-T7665
It depends on your phone system, the smaller ones, 50, have modular jacks to distribute the extensions and you can simply move the pluged in extension wiring on the control unit, for instance if you are 102 and the other phone is 103, simply swap the plugs on the main control unit. The larger Panasonics have direct wiring so you need a punch tool and some cross wire to move an extension.
Oct 01, 2009 | Panasonic KX-T7633 Corded Phone
Not in service
Whoops, the second part of that is press FEATURE *0 and the intercom button before you move it and see what extension it is.
Do the same thing after you move it. It will tell you what extension it is and if it stayed the same.
The system CoOrdinator or installer can turn off that Auto Set Relocation feature :-)
Carl
Sep 17, 2009 | NorStar Lands Phones
Moving extention number
you must change the number by programing the PBX or phisicaly change the jack in the PBX.Both solutions must be done by authorized personal.check who is serviceing your pbx and make a request.
Sep 15, 2009 | NorStar T7316E Corded Phone
Change/reprogram extensions
The easiest way to do this is move the cross connect in the closet. Get the jack number from each location and swapped the cross connect(wire). You could change the extension number in MB4-10 but it depends on the type of system you have.
Nov 18, 2008 | NEC DTU 8-1 Corded Phone
Station (extension) names
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Right intercom
enter the extension you want to modify
press the left intercom
Enter the name.
When finished, press feature 00 to exit programming.
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
Panasonic KX-T7453 Corded Phone Logo
140 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
