Question about Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Double Oven JDR 8895
I have in the past cleaned both the top and bottom ovens, but now when I push the CLEAN button, it only beeps at me, twice but won't allow anything else. All other buttonhs work fine. I cannot locate my book and realize I was given two installation books only. If you can help, I'd appreciate it. Thanks
  • Ronny1 Jan 17, 2008
    This is for a Jenn-Air Double oven, JDR8895, I pulled that site and it said maytag and that was not available. Is there a sit for Jenn Air? Thank you.
    President:
  • 1,314 Answers
Http://www.maytag.com/support/manuals_literature.jsp first go here and download a new manuel if nothing you can fix reply to me and ill look in the service manuel ok
Posted on Jan 17, 2008
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
I have a GE oven and when I try to clean it, I push the "clean button" and the oven starts beeping and the door button flashes. What do I do?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Dec 27, 2010 | Ovens
Installed 4/09,. Bottom oven won't start.
This is an easy one. If it was installed 4/09 then its still in warranty. Unless you've had it for over a year before installing it. It's more then likely something with the control board, but I would get someone out there since it's still in warranty.
Nov 26, 2009 | Jenn-Air JJW8230D Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Jenn-Air JJW8230D Electric Double Oven Logo
304 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
