Question about SanDisk Sansa Clip MP3 Player
Battery won't show full charge
I own the sansa clip mp3 2 Gb player and I have been charging the player via USB for about 24hrs. Still doesn't show a full charge. Could someone please advise? Is there something that I might be doing wrong?
  • 1 more comment
  • waterlily Jan 19, 2008
    Hi...I also charged my Sansa Clip for 24 hours and it shows only 1 bar (not fully charged)??????? What should I do?????
  • redbutterfly Feb 14, 2008
    Somehow I was able to charge it (once) but I can't remember exactly how I did it... Since then I couldn't use it and it won't charge it no matter what I do.
    Can anybody help us, please? Thanks!
  • Anonymous May 09, 2008
    will i get seperate charger as i dnt have system
  • 3 Answers
I called sandisk. You have to have service pack 2 on your windows XP and you have to have Windows Media Player version 10 or 11. One one of my laptops I had version 9 and it wouldn't work, I changed laptops and it works just fine.
Posted on Jan 26, 2008
If i plug my player to pc it shows charging and full charge but if i disconnect it will appear lowbat in the screen. and my pc doesn't dettect my unit
Try turning off the player and then back on again. The battery status should update and show full charge. Restart your PC and reconnect the player and it should appear again.
Simply pulling out the USB cable can cause a communication error, so it's always best to use the 'Eject USB device' option. When you want to disconnect, the player will be listed as an external hard drive when you open up 'My Computer', right click on the drive and select 'Eject'.
Jun 13, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk 2GB Sansa clip will not charge with USB.
The problem maybe the usb cord or it maybe the hardrive in the monitor hooked up to the network drive. If this doesent help i will try to help as much as possible.
May 22, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sandisk Sansa Clip 2GB not detected by XP SP2
Change the USB Mode to auto-detect and see if you get better results. If that fails, switch entirely to MTP mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
Not being charged?
Sandisk Sansa Clip FAQ
The detection problem is addressed at that link.
Feb 06, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip
Assuming charge is from computer or laptop, you need the following programs: Windows XP Service Pack 2 & Windows Media Player 10 or 11. Good luck!
May 07, 2008 | SanDisk Sansa Clip MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
525 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
