Question about Gateway GTW-P42M303 42 in. Plasma Television
GATEWAY BUZZING VERY LOUD AND PICTURE GHOST LIKE IMAGES
My Gateway 42" Plasma is about 3 years old. About one month it started buzzing very noticeably. It gets very loud now, especially when the screen is on a menu screen.
The picture is starting to go as well. When it turns on it the images shake in weird colors. This seems to slowly go away after the tv warms up. There are also images that kind of remain from a previous scene from a show that lingers and shakes a few seconds then it disappears.
Any idea what is wrong? I'm almost ready to dump it and buy a cheap LCD Vizio. But I thought it may be worth trying to fix it.
  • generalten Mar 24, 2008
    Our GATEWAY has been buzzing for 4 years. It starts about 10 seconds after the TV turns on. It is very irritating.
  • Dubb 1 May 29, 2008
    When I turn my 42 in. Gateway Plasma on, shortly after it starts to buzz.It only buzzes when theres a picture on screen and when the picture changes the pitch changes to.
I have the same problem with the noise and the video quality is ****, my friend gave it to me to see if i could fix it, i took it apart and the sound is coming from either an orange thing or a capacitor, could it be an overload capacitor where the sound is a bunch of sparks flying through the dielectric?
Posted on Mar 15, 2008
My mitsubishi pd 4225 has developed a double picture. It started as a ghost image when there was a lot of blackness on the screen, then there was a loud pop, and a loud buzz. I have had a double picture...
Try replacing the Tcon board, generally this kind of thing comes with that board failing. As far as the part number you will need to get that off the old board as they use more than one board in the same model set
Dec 20, 2017 | Mitsubishi PD-4225 42 in. Plasma...
Gateway 46 in plasma
It sounds like the gas in your screen has exhausted it's life. From the information I have gotten from different manufacturers, there is about a 5 yr life expectancy on the screens of most plasma sets.
My guess from the symptom you describe is that you will need to replace the screen.
Thanks/mike
Jan 05, 2008 | Gateway PLSM46TV 46 in. Television
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Gateway 42" plasma has sound only, no picture. 6 years old
Gateway 50" plasma tv #7005406 runs only in black and white after power outage. Menu screen still in color.
Mar 01, 2010 | Gateway GTW-P42M303 42 in. Plasma...
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
No sound, no picture following a mini explosion in the rear
yes it can be repaired, the y-sus and z-sus boards are most likely bad. would require a qualified shop to repair it as there are adjustments to be made to the new boards.
Jul 22, 2009 | Televison & Video
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
Gateway plasma
Sounds like your Y-Z sustain boards. You will need to get pro help and you should be looking at a repair or 400.00
Classtorations.com
Jun 12, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Sound but no picture
Just soldering all cn13 wires directly to the board. It will work fine.
Sep 10, 2007 | Gateway GTW-P42M303 42 in. Plasma...
Gateway GTW-P42M303 42 in. Plasma Television Logo
287 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
