Question about Asrock 775i945GZ Motherboard
Continuously reboots my computer just reboots and reboots
  • Marian131435 Jun 07, 2008
    My computer continusly reboots. I tried to disable the hard drive like it told me too. Then it comes up with a black screen that sais Operating System not found.
  • janetloyley Jan 25, 2009
    will not stay on .just reboots all the time
Your cpu is overheating read this link:
http://www.supremelaw.org/systems/heatsinks/warning.htm
Posted on Jul 21, 2009
  • 53 Answers
Hi there
First you will need to boot up. When you do this you need to go into bios and then go to boot and disable the hard drive floppy and any other drivers. You must make sure you keep the cd driver as 'able', save setting and exit out of bios. This will let you reboot. After it`s done, the partition in the computer will reboot the computer. Make sure to go back into bios and able the hard drive, floppy etc...
I had the same problem, and solved it this way.
Posted on Jan 17, 2008
How do i log on to the safeboot mobile data security on my pc
Answer: To get into Safe Mode with Networking: 1.Log out and reboot your machine. 2.When the machine starts the reboot sequence, press the F8 key repeatedly. 3.Select Safe Mode with Networking from the resulting menu. 4.Login. If malware has changed your password, try logging in as Administrator. By default, Administrator has no password. 5.The machine will continue booting, but the Windows desktop will look different. 6.When you're finished doing what you need to do, log out and reboot back into normal mode. Hope that helps.
Mar 23, 2011 | Computers & Internet
What will happen to the hard drive in power failure?
Power failure as in whole house power failure? Or the computer's power supply failure?
Whole house failure, nothing, the computer will shut off and require rebooting, at which time you may receive a message the computer was not properly shut down, just continue as normal.
Computer power supply failure, same thing, nothing, except the computer will not reboot as the power supply has failed.
Jun 15, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
My dell computer won't reboot. How do I reboot it from a cd?
If you are running Windows XP, open the DVD tray (if you could), then load the Win XP installer.
Restart the computer, and it will tell you to press any key if you would like to boot from CD.
Just hit any key and your computer should reboot using the CD.
Thank you and good luck!
Apr 26, 2010 | Dell XPS 200 PC Desktop
Computer continuously reboots after loading software
Do a system restore to the restore point before you downloaded the program.
May 09, 2009 | Disney Pix Micro Digital Camera
Computer crash and restart
Windows restarts without warning
Cause:
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Jan 28, 2009 | Computers & Internet
Computer keeps rebooting
just check if you get a blue screen with lots of text messages just before your PC reboots. also if you have any hardware knowledge or if not ... get your vendor to check the RAM and also check if your CPU fan is working properly.... let me know...
Dec 03, 2008 | Microsoft Windows XP Home Edition
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks honglake@gmail.com
Nov 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Asrock 775i945GZ Motherboard Logo
314 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
