Where can I download the drivers for my office copier/printer to work with my new macbook pro? The printer is a Konica minolta (Bizhub c350) PCL5c Printer. I have switched over to mac because my PC was stolen. I have drivers for PC, but they are not compatible.
Thanks,
Dr
Comment by doctort, posted on Jan 17, 2008
There are drivers for the Mac, someone else had the drivers and I have already downloaded them. Thanks for trying.
hey, do you have a link to those mac drivers? I have the same problem, have a mac, and can't find drivers to my c350...
Best Solution
posted on Jul 22, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
Basically all priners use the same protocols. Mostly we have PPD and NOW PCL5. Right now I´m using a workcentre c226 however all the drivers I found on the Xerox homepage were PPD... they didn´t work. This is what I did: I whent to Sistem Preferences->Print&Fax->(select your printer in the left side)->Options&Supplies->Driver->Select Driver to use...
Now using spotlight or reading all the drivers search for a printer that uses PCL5 and thats it. It doesn´t mater if its not the model you have. For example with the WorkCentre c226 I use the driver of a HP LaserJet 3P w/ PCL5.
Was this solution helpful? Show your Appreciation by rating it:
