Question about RCA F36650 36" TV
Horizontal line The tv just started this maybe 4 months ago. The screen will flicker and you can hear an extremely high pitch whine. From top to bottom of the screen, the 1st 5" or so is fine then the next 3-6" of the picture compress into a single bright horizontal line, and the last of the picture looks fine but it is about 3-6" higher which leaves a large black area at the very bottom. The tv seems to discharge alot of static following unplugging it. So much in fact that I have been painfully shocked when accidentally placing my hand on the tube while I had the plug in my hand. (part of my finger was touching the prongs of the plug) What could this be?
  • 1 more comment
  • SaucyDE Jan 17, 2008
    Brand - RCA
    Model - F32650
    Chassis - ATC113CA1
    Does this help? Sometimes turning it off and unplugging it for 1-2 min will fix the problem temporarily.....How much are those pieces? Can this be done safely by someone with soldering, mobile a/v, and computer upgrade exp. ?
  • spliceran Jan 20, 2008
    i install a new eprom ic & i need help to set it up ?
  • Jaime Hernandez May 11, 2010
    Could you please include the chassis number if possible?
  • 2,336 Answers
It looks like the squeal or high pitch is produced by the flyback part # 257805. Also check the the secondary side of the power supply for around 130VDC if that voltage is found to be lower than 120VDC I would suggest to replace CP80 with a 100 mfd@250 vdc. Part # 218374
Globalsemi.com has these parts, for the flyback transformer just type in search for FLY-391, this one is cheaper than the genuine(257805) fly back.
Good Luck.
Posted on Jan 17, 2008
Monitor no raster power has been ok
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no High Voltage, you either have a low voltage power supply problem, bad start up circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have High Voltage as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HIGH VOLTAGE), you probably have a start up problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for start up problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
hope this helps......
Aug 06, 2010 | SAMTRON 77V 17" CRT Monitor
My tv has gone black how can i fix it or get a repair
Assuming there is no deflection and no HV, you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
(If you have HV as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
If there is voltage and no deflection (no high pitched whine and no HV), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
Jun 02, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My hm67 50 inch sond but not pic heard loud pop and lost pic
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself). See the section: Bypassing the Startup Circuit for details.
May 31, 2010 | Televison & Video
How do you fix a ps42p7 plasma tv that has sound and no picture. i have checked the cables and changed tv's and it is not any other source for the problem.
Assuming there is no deflection and no High Voltage , you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
If there is voltage and no deflection (no high pitched whine and no High Voltage), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osillator. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Hope this help
May 30, 2010 | Televison & Video
No Picture or sound
Good luck...
May 29, 2010 | Sony KV-32HS20 32" TV
Jvc flat screen
Hello, The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
If there is voltage and no deflection (no high pitched whine and no HV), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available.Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself). This require a skilled personnel to handle this
May 20, 2010 | JVC LT42E478 42 in. HDTV
Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Aug 08, 2009 | Polaroid FLM-3232 Television
High pich whine from CT-36D32 36" TV
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Feb 05, 2008 | Panasonic CT-36D32 36" TV
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
RCA F36650 36" TV Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
