Question about RCA F27450 27" TV
CODE F13 ON HOTPOINT AQUARIUS WASHER/DRYER
A CODE F13 CAME ON THE CONTROL PANEL OF MY HOTPOINT AQUARIUS WASHER/DRYER. WHAT DOES THIS MEAN? ANY CORRECT ANSWERS WOULD BE GRATEFULLY RECEIVED
  • Anonymous Jan 22, 2008
    i am having the same with my hotpoint aquarius washer/dryer. its only 1 yr old and have had numerous problems with it already. any answers? e mail me on snoop280883@aol.com
    i am having same problem. amongst many others! its only 1 yr old too! any help would be grateful. e mail me on snoop280883@aol.com
    Sergeant:
  • 282 Answers
Do u want to resolve the f-13 fault code on HOTPOINT Washer Dryer units
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 - 20 pounds sterling from Hotpoint or other spares stores. CODE F13 ON HOTPOINT AQUARIUS WASHER/DRYER - code-f13-hotpoint-aquarius-washer-dryer-brswrwcy453xu5qdcnkktuei-3-0.jpg code-f13-hotpoint-aquarius-washer-dryer-brswrwcy453xu5qdcnkktuei-3-5.jpg
Posted on Nov 15, 2014
Its the safety thermostat on the top off the drying element
Posted on Mar 04, 2008
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
My aquarius washer/dryer wd645 is flashing f-07
dont warry it will be for few time then it will be ok
Mar 30, 2015 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Flashing f 13 and leaking from bottom
Hello,this is an error with most of the Branded Washers like Hotpoint etc,
F13 indicates High Dryer Temperature.
Check the dryer motor runs OK and that the fan isn't hanging off. (You'll hear it if it is).
Check the connections to the dryer NTC (temperature sensor on top of dryer)
Check the condenser isn't blocked (under the fan motor, plastic unit going down the rear of the tub).
If all checks out OK, try changing the dryer NTC.
Thanks
Jun 10, 2010 | Hotpoint Aquarius WD640 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Sep 02, 2007 | Hotpoint Aquarius WD640 Front Load...
F 13 ???????
f13 means the dryer heater is not working the thermal fuse on top of the dryer that connects inline with the heater is open circuit this is most likely due to the fan dropping and stalling causing the overheat or poor airflow due to a buildup of fluff in the dryer
Jan 28, 2007 | Hotpoint Aquarius WD640 Front Load...
RCA F27450 27" TV Logo
518 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
