Boot i removed the cmos battery with a long wooden pencils eraser after putting thenew battery in i can boot but not have results on the monitor
  • charlesspeed Dec 25, 2008
    my m2a-vm will power up but will not beep of post and no video sig..?
  • 2,427 Answers
Take the Battery out again and clean the contact points on the main board battery connector, Remove the memory and ensure your system is unplugged. Hit the power button 7 times and then replace battery and memory..
Now boot the system..
You will need to enter the bios setup by pressing the key it suggest to do that (IT WILL BE DISPLAED ON THE SCREEN)
loat the optamised or failsafe defaults, save and exit...
Posted on Jan 17, 2008
My vivitar auto thyristor 550 FD wont turn on
If the corrosion was from alkaline batteries you may use a damp cloth. But before you do that, try using a wooden pencil with a red rubber eraser. This is likely to remove the corrosion without risk of introducing water inside the flash.
Jan 30, 2014 | Vivitar Cameras
Toshiba Satellite U405-S2824 startup beep code error
The beep you hear is a BIOS Beep Code. The computer's way of telling you something is wrong, and a general area to look into for it.
A short repeated beep over a long period, usually indicates a Ram Memory problem.
Remove ALL power to the notebook. Remove the AC adapter (Charger), and Battery.
Suggest you remove all ram memory modules, and clean the gold plated contact pins at the bottom.
Use a pencil eraser. If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band touch the contact pins. Reinstall the ram memory module/s.
Reinstall the Battery, then the AC adapter. WAIT 1 minute, then turn the notebook on.
Post back in a Comment as to the results.
Dec 31, 2011 | Toshiba Satellite U405-S2824 PC Notebook
I have a toshiba satellite A215 S6804 lapto that since boot starts asking me for a password, and remove the CMOS battery, but the problem persists, your BIOS is PhoenixBIOS is not normally the password is...
this laptop most probably belonged to someone else who put a password on bios. Removing the back-up battery did not erase bios protections, only the date and time. To erase bios is necessary specially equipment and is not cheap.
Sep 11, 2017 | Toshiba PSAFGU-058002 Notebook
Hi there, my PC closed down last night for updates (I think) and this morning I cant get it to work. My monitor is saying there is no video input but there is a green light on my hardrive. I have tried...
try to look the VGA cable. maybe it just loosing the connection. or the power cable.. if nothings happen. open your unit and clean the IC of your Memory RAM with pencil eraser. make sure that you touch a metal for about 5sec before you pull out the RAM.. its because you have a ESD in your hands. after that.. put back your clean RAM. and power on your unit. hope this will help.. or.. i remember.. you can also try to remove the battery and flash your CMOS jumper settings to 2-3 settings.. then after 5sec. put it back to settings 1-2.. thx
Jul 07, 2011 | Computers & Internet
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
My system was working fine suddenly the MB is not booting or posting.and no display. Now I disconnected all the device except CPU ( AMD Processor) got the beep connected RAM no diaplay HDD led no...
Double check cable from the motherboard to your hardisk likeIDE or SATA together with the power cord
just make sure if its fully inserted. boot up the pc press delete to check UPTHE BOIS IF THE HARDISK is connected. RAM( Random Access Memory) maybe defective. replace it to thenew one and boot up your desktop. sometimes if the onboard /vga, (video graphics adpter) are defective its also beepingrapidly. also try to clean up your ram using pencil eraser.
Feb 09, 2011 | ASUS K8V-MX Motherboard
Acer Extensa 5210 blank screen
re seat the memory cards, clean them if necessary with pencil eraser (the metal connector on mem card), if it won't work, you might need to replace them with the new ones
May 04, 2010 | Acer Extensa EX4420-5239 Notebook
After a computer reboot the monitor would not turn back on.
firstly check out ur wire connection if its proper then remove ur RAM take a eraser rub the Ram nd insert it again nd also check out wether ur CMOS battery is working or not u will surely get a positive result.....
Aug 30, 2009 | Dell E173FP 17" LCD Monitor
AV8 Motherboad post code C5 freezes on boot.
Try cleaning the contact point of the memory modules "with a pencil eraser" and insert them back... Clean also the Processor heat sink if dusty... Then check the voltage of the CMOS (3V) battery it maybe dead, if so you need to replace that with the same type.
Keep me posted if still does not work...
Happy fixya...
Feb 28, 2009 | Abit AV8 Motherboard
Black screen on monitor
Hi there
Remove the side panel from the desktop and clear the cmos >>> cce5f1a.jpgmove the plastic jumper to the other position, and turn the machine on, if nothing happens, you have cleared the cmos, put the jumper back in its original position and see it the PC boots. If there is no Jumper, take the battery out for an hour.
Remember to remove the power cord before you take the side panel off.
Post back with the results please
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
729 people viewed this question
David Payne
David Payne
