Question about Coffee Makers & Espresso Machines
Krups Grind & Brew KM7000
The grinder does not come on-just a click. Just got machine for x-mas -used the grinding feature 3-4 times yesterday it stopped grinding, but the rest of the process continues-just no coffee ground into basket. It does not appear to be obstructed.
  • 4 more comments
  • nguma Jun 16, 2008
    I have the same problem with the Cuisinart Grind and Brew. I only used it about three times before this started happening. And I paid a lot for it!
  • djohns Oct 19, 2008
    We bought a Krups KM7000 grind & brew about 3 weeks ago. This morning the grinder stopped working. The filter part snaps across as it's supposed to but the grinder doesn't grind. So far we've tried to clean the hopper including with vacuum. No luck so far. The screws for the grinder assembly are obviously proprietary and we don't want to nullify the warrenty. Anyone else figure out how to fix this without sending the entire machine back?
  • Sbuck Dec 07, 2008
    This machine about 2 yrs old. Besides intermittent water leaking and puddling when pouring from the carafe, it worked ok. yesterday the grinder worked for one cycle, then later in day would not grind at all. Manual doesn't tell how to test for burned out motor or stuck/jammed grinder. Am now running by doing the grinding in an old Melita grinder that has worked fine for 15 yrs., then brewing in the Krapp machine.
  • Anonymous Feb 10, 2009
    i've had my km7000 for a while, and now, it just won't grind.
  • Anonymous Apr 14, 2009
    Grinder just hums. The machine is about 9 months old, used once or twice a day. I turned it sideways and shook it, but that didn't work.
  • Douglas Mader Dec 04, 2011
    Ran across this when I was posting a question for the same problem. Can you advise how to disassemble the grinder housing to access the microswitch?
    Problem Solver:
Krups km7000 Stopped cycling water
Posted on Feb 06, 2010
    Scholar:
  • 22 Answers
The grinder is activated by a microswitch inside the grinder housing. Under normal circumstances, the microswitch gets closed by swinging the filter lid 'away' from the filter (i.e. into the grind position).
Unfortunately, sometimes the microswitch works itself loose, and no longer closes when you swing the filter lid open, so the grinder doesn't come on, since it thinks the filter lid is still in the way.
This seems to be a common problem with this rig. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz
Posted on Jan 31, 2010
  • 2,039 Answers
If you dont have something jamming the grinder look like blow grinder motor you can trie activate the grinder at the same time gently tap the side off machine maybe what ever blocking the grinder gonna come off if not tank good for warranty good luck cheers
Posted on Jan 17, 2008
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
Krups KM7000 won't make a full pot.
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Oct 18, 2012 | Krups KM7000 10 cup Grind and Brew coffee...
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this...
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Sep 30, 2011 | Krups KM7000
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
How do you grind the coffee beans
open the brew baSKET LEVER UNTIL IT LOCKS, THEN TURN THE MACHINE ON.
Jul 12, 2009 | Krups KM7000
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
703 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
