Question about Samsung HL-P6163W 61" TV
Buzzing sound There is a loud buzzing sound coming out of the TV. It can be dwarfed if the TV is very loud, as it does not increase as the volume increases. It is there whenever the TV is turned on. I have the 61 inch model and have that same buzzing sound. Sounds like a leaf or something rubbing against a fan blade but at a lower pitch. Anyway starts as soon as TV is turned on and is consistant regardless of TV volume. I tried to clean of dust from two of the small fans that I could get at thru the acessess way for the lamp but it had no effect. What is causing this aggrevating sound? How can it be fixed?
  • 281 Answers
The sound is a result of the faulty CRT base, and you will have to replace the base socket. Make sure you by the exact same type of base, and if you are not a techie, get a qualified technician, this is not a costly problem.
Posted on Jan 23, 2008
How do I increase the sound volume of myToshiba Satellite L755 laptop
By the clock at bottom right there is a speaker icon that can increase volume. right click on it and click sounds, click playback tab at top, Right click on speakers and select properties, should be an enhancment tab for bass boost and loudness.
Feb 12, 2012 | Computers & Internet
Yesterday i have bought a brand new CD 740 A and 650 C. Both the things where fixed with Bose AM5. It sounds really good. when the volume is increased more than half, the loudness too increases. is there...
Please note that you volume control increases in a logarithmic scale, in simple words it increases in a doubling scale eg: 2,4,8,16,32,64------------. So if your half volume is 16watts per channel the next increase is 32 and the next 64 so on. So don't be surprised if after half volume it suddenly starts getting very loud. There is nothing you can do about it.
Jul 28, 2011 | Cambridge 740A Amplifier
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Apr 16, 2009 | Televison & Video
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Loud buzzing noise
oil the blade with clipper oil, a couple of drops on the teeth
Oct 28, 2007 | Oster 76974-160 Hair Trimmer
Buzzing sound
It is a problem with the flyback transformer...R u good at electrical circuits?If yes you can unsolder the old one re-solder the new one and check it for high-voltage..
If you are not good at this i advice you not to open it coz there's always a risk of high voltage..Anyways if you want to get it repaired it should cost you aroun 75-100$
Oct 18, 2007 | Samsung HL-P5663W 56" Rear Projection HDTV
Samsung HL-P6163W 61" TV Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
