I have the same problem with my laptop. Here is my understanding of the problem.
Many laptops have a BIOS limit of 128GB hard drive capacity.
Try to find the latest BIOS available for the laptop, and see if it supports 48-bit LBA addressing of the hard drive.
If the BIOS only supports 24-bit LBA addressing, there are tools to restrict the size of the drive.
DISCLAIMER: I have read of Dynamic Drive Overlay (or Drive Dynamic Overlay) software, which is supposed to allow for the use of larger drives. I have not used one, so I do not know how well they work. I am sure they slow down access and, from what I have read, they do not work with Vista or Windows 7.
Transfer an Operating System to a New Hard Drive
When replacing an old hard drive, a process known as cloning is the easiest and most thorough method for transferring data between the old and new hard drives.
A cloning utility takes a snapshot of your current hard drive and then re-creates that snapshot on your new hard drive.
The process clones everything, including the operating system, installed applications, settings and personal files.
Create a system restore disk so that you can return your system to its previous condition if an error occurs.
You can use a backup and restore utility provided with your operating system, or find one for free or for purchase on the Internet.
Many cloning utilities can also create system restore disks.
Shut down the computer and remove power.
Physically install the new hard drive.
Restore power and boot up the computer.
Ensure that your operating system recognizes that the new hard drive has been installed.
Pick the cloning utility that works best for you. (See Below for some options.)
http://www.easeus.com/disk-copy
http://www.runtime.org/driveimage-xml.htm
All freeware
http://www.acronis.com/homecomputing/products/trueimage
http://www.symantec.com/norton/ghost
Purchase
Base your decision on your operating system and the cost and complexity of the utility.
Install and launch the cloning utility on your old hard drive.
Follow the instructions included with the cloning utility.
Keep the old hard drive as a backup, or reformat it for additional storage space.
Cloning a Notebook Hard Drive
Pick the cloning utility that best fits your needs. (See Above for some options.)
Base your decision on your operating system, the cost and complexity of the utility, and whether the utility can clone notebook hard drives using bootable media, such as CD-ROMs, DVD-ROMs or flash drives.
Keep the old drive as a backup in case the new hard drive fails.
or
Copy an OS to Another Hard Drive
Copying an OS or operating system to another hard drive can serve several functions.
Some simply want to move their current operating environment to a new PC, while others are replacing an old system hard drive with a newer one and want to avoid the hassle of updating and reinstalling.
The process of copying your operating system to another hard drive is a very easy one, in fact, and can be accomplished by anyone with nothing more than some software and some time.
Install Acronis True Image and launch it from its installation icon.
A link is provided below for the Acronis free 15-day trial.
http://www.acronis.com/homecomputing/download/trueimage/
Support free software or g4u WILL die!
http://www.macrium.com/reflectfree.asp
Macrium has a free also pay options
Click the "Utilities" button from the left menu bar.
Click the "Clone Disk" button from the right pane of the main program window.
This will cause a dialog box to appear.
Click the "Next" button on the bottom-right corner of the dialog box.
Select the disk with the operating system you wish to copy from the drive list and click the "Next" button.
This will begin an examination of your hard disk that will finish in a few minutes.
Select the destination disk from the hard drive list and click the "Next" button.
Choose the "As-is" option for how you would like to handle your partitions.
This option merely lets you decide whether to keep all partitions on the drive or copy just the data onto one blank partition on the new drive.
Click the "Finish" button, and Acronis will prompt you that your system needs to be restarted to begin the cloning process.
The restart will happen automatically when you click the "Finish" button.
Allow the computer to restart, and Acronis will launch prior to the operating system and begin the cloning procedure.
This process may take several minutes to several hours, depending on the size of the operating system and whether there are any installed applications.
Restart you computer once again after Acronis has completed the cloning procedure.
The software will notify you when the cloning has finished.
Boot into your operating system and use your new operating system installation as normal. You may now remove your old operating system drive or format it as you desire.
Hope this helps.
