Question about Mintek DTV-373-D 37 in. LCD HDTV
Remote doesn't work
The remote only functions for the on/off mode. Cannot access menu, change channels, adjust volume, etc. Cannot manually utilize these features either on the TV itself. It is "stuck" on one channel and at one volume level. My remote doesn't work, it will turn the tv off and on, but I can't change channels, the only thing I can see is a five minute review of a dvd I played last and it is playing in a memory replay, which I did not program the computer to play in that mode. I have tried everything I could, but it still will not work.
  • 5 more comments
  • 5125 Jan 23, 2008
    I tried unpluging the tv from wall socket and it still didn't work.
    5125
  • HHinAA Jan 27, 2008
    We are having same problem. I put a dvd in it hoping to knock it back and now we can only watch that dvd -- can't work the tv or dvd buttons.
  • Tjedlin Feb 03, 2008
    I have exactly the same problem.
  • Anonymous Feb 03, 2008
    Ihave the same problem
  • Anonymous Feb 10, 2008
    remote does not work except to turn tv on and off buttons on the tv do not work either volumn not able to adjust up or down
  • heater1951 Mar 19, 2008
    we are having the same problem with the volume, no sound, remote does not work at all
    already unpluged the tv from the power and still does not work
  • brettcraft1 Sep 11, 2008
I have the same problem
Posted on Jan 18, 2011
    Problem Solver:
  • 11 Answers
Check out my fix here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Hope it helps!
Posted on Feb 12, 2008
    Genius:
  • 1,003 Answers
Unplug from the wall socket and plug back in and try
Posted on Jan 17, 2008
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
We purchased a tv from a school channels only goes up to 02-13 cannot go any farther. We are using a universal remote that when we go to menu to channels it doesn't allow you to either enter or delete...
U can't do much on a universal tv remote.Only the basic mostly,like power on/off,channels up/down and volume up/down that about it.If u wanted more functions and controls and adjustments inside of the tv Menu for options like changing and adding functions.U must have the tv original remote to be able to do it.Try website like Remotes.com to buy the tv orignal remote.
Aug 29, 2011 | Philips 32MF231D Television
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Any television remote will give full access to the television functions. The remote must be specific to that television. Google
make model replacement remote
There are original ones on ebay, plus companies that sell remotes that are an exact copy. The CT90326 may be for another Toshiba model, or of course it may be faulty.
Then we have the remote on the cable or satellite unit. That gives full command of the unit functions, but BASIC control of the television, normally On, Off, Channel Up and down to allow access to DVD or similar and Volume Up and Down. Everything else is done from the TV Remote.
To get the cable remote to make that happen, you Google
Toshiba Remote Codes
and run through them all until a selected code allows you to switch the television on and off.
Sep 25, 2017 | Toshiba Televison & Video
Just bought one of these used and need to adjust the color brightness contrast etc. I assume I do this thru the "menu" option. I don't have the original remote with the unit and I can't get any universal...
Try website like Remotes.com to buy the original remote it ur best bet.Tries the manual control on the tv.Push the Menu button use the channel + - and the volume + - on the manual buttons to adjust colors,contrast,brightness.
Jul 04, 2010 | GE 13TVR62 Combo
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Convergence adjustment @ 52MH84
press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
Jan 21, 2008 | Televison & Video
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Remote doesn't work
According to Mintek support you should unplug your set for 30 minutes which is a reset/rebooting process. Then plug it in and hold the DVD eject button for 5 seconds [at least]. The DVD should eject unless there is another problem. If it doesn't eject then call Mintek support at 877-646-8358 for help. They told me you have to send the TV to them and they'll send a new one. If you have to do that then make sure you tell them you want your DVD returned when they get it out. Good luck.
Nov 22, 2006 | Mintek DTV-263 26 in. TV/DVD Combo
Mintek DTV-373-D 37 in. LCD HDTV Logo
196 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
