Question about Samsung SyncMaster 17" TFT LCD Monitor
Dark scree My Samsung SyncMaster 170MP screen has darkened considerably. I can see the screen icons and images but they are dimmed a lot. It was OK until I lost power. When the power came back, for no appearant reason this condition was present. NO settings were changed. When the brightness is adjusted up or down, nothing happens to brighten or dim the screen. My Questions is: How do I get the screen to brighten up back to normal levels? Please help.
  • 6 more comments
  • stoner219 Feb 22, 2008
    We have the same problem, the tv works great, but when switched to pc it is so dark you can't use it.
  • lasereye Mar 01, 2008
    I am having the same problem. Worked perfect till I shut it off and moved my pc to the other side of the room - now I've got a dimmed screen. Adjusting contrast & brightness has no affect. TV side looks great as usual. Duuuu...What is going on here?
  • David Zier
    David Zier Jun 11, 2008
    I've got the same problem, the first time it was replaced undr warranty, now it's no longer under warranty. These things aint cheap either!
  • Anonymous Dec 28, 2008
    So what is the fix?
  • mike samsung Dec 28, 2008
    The PC screen just went dim. TV is fine. Adjusting the brightness, contrast etc does nothiing for the PC. So what is the fix?
  • cs_mihcael Feb 01, 2009
    I got same problem
  • Anonymous Feb 03, 2009
    Same problem but I'm not seeing any solutions.
  • Anonymous Feb 17, 2009
    I also have the same problem of incredibly dim and blurry PC feed but the TV and video feeds are still good quality -- these feeds have not deteriorated over time like the PC feed. Does this mean there is no apparent solution other than the trash can?
    Problem Solver:
  • 6 Answers
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Posted on Sep 08, 2008
  • 30 Answers
If you had try to adjust the brightness or contrast button but nothing effect on the screen. Then this will confirm your lcd monitor have problem. This problem are because of the inverter board or ccfl lamp. If you need more information on repair this type of problem, please go to http://www.fastrepairguide.com . Thanks
Posted on Jan 18, 2008
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
After you turned it on and the screen blacked out
It sounds like you just have a bad backlight power supply. Go to our web site at: www.ccl-la.com We have repair guides for many models of LCD monitors and the 204B guide should also work for your unit.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 12, 2009 | Samsung SyncMaster 203B LCD Monitor
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Computers & Internet Logo
708 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
