Question about LaCie (300770) 250 GB Hard Drive
Lacie external HD problems
I have a Lacie 250GB External USB2.0 7200rpm 250 GB USB 2.0. I've had it well over two years with no problems. Recently my computer crashed so I had to reinstall. Before the reinstall the drive functioned perfectly. As of now anytime I turn it on I recognizes that a storage device has been introduced, saying that it can perform faster (as I don't have USB 2.0 ports installed) but after that it won't show in explorer. Has it taken a crap dive or can I fix this? Thank you for your time.
  • 788 Answers
I would suspect your USB drivers. Go into device manager and remove (uninstall) any device under the USB heading. Reboot and see if it works better. Also I would try the drive on another computer to make sure it is working find and try a different USB cable just in case.
Posted on Jan 17, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ... > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My LaCie 250 GB external hard drive is plugged in and the orange light is on. It's not showing up in my computer but when I go to device manager it's there. If I double click on the device it says code 10...
Unfortunately hard drives are a pain when they have problems.
First try a different USB port to make sure that there is a problem with the port.
With my experience on broking external hard drives, I am guessing that your HDD motor is not spinning.
Some things you can try for this (should be done with an experienced individual)
- Take the HDD out of the case and place it in another external case (easily found at Best Buy or online (I buy mine from Milwaukee PC)). This solution has helped me in the past.
- If the drive is failing to initialize you just may have to replace it. If you want your files to be recovered you can send the drive in to repair shops and they can try to recover the files BUT this is NOT cheap.
- Simply buy a new external, they are pretty cheap these days (especially 250gb).
Hope this helps :)
Jan 25, 2011 | LaCie (301074) 80 GB Hard Drive
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Error code 16
Code 16 is a hardware or firmware failure you need to Surf a little and reveiw the home page. Hold on ill get the address to take you too the solution
This may resolve the problem and grant you access to your HD
Oct 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My Lacie HD will not show up on my MacBookPro when plugged
Brand new? It needs to be formatted / erased with the disk utility to work with your mac.
Jul 07, 2009 | LaCie (300728U) 250 GB Hard Drive
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Problem to start my external packard bell usb 2.0 250 GB hard drive
Sounds like the drive is dying. Is it externally powered, or powered through the USB port? How old is the drive? When you say 'strange' what does it sound like?
Jan 08, 2008 | LaCie USB 2.0 Mobile 60GB 5400rpm 480Mbps...
LaCie (300770) 250 GB Hard Drive Logo
170 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
